Issue with brakes 2010
Old Jul 27, 2020 | 05:50 AM
Rachel28's Avatar
Hi. My car has been making those funny sounds,either when I am driving and/or braking,like a hiss sound or a squealing noise. Can anyone help me figure out ? I have been spending far too much money with this car and was wonderinf if i should wait until the next servicing ,in 5k kms.
Thanks 😊
Old Jul 27, 2020 | 11:36 AM
56chevydan's Avatar
It sounds like you need to have your front disc brake pads checked out for wear. The squealing sound is probably coming from a thin scraper plate that is built into the front disc brake pads that starts scraping against the rotors when the pads wear down to a minimum thickness.
Old Jul 28, 2020 | 05:25 AM
Rachel28's Avatar
Many thanks!I thought so but wanted to confirm..
Old Jul 29, 2020 | 04:02 PM
armcast's Avatar
Definitely check the front pads as 56chevydan mentioned. They could be worn down, if they're not make sure you put a little caliper grease on the backs (where the caliper makes contact with the pads) when you put them back in. Sometimes brake squeaks are caused by no lubrication on the slide pins, clips, or back of pads. Good luck!
Old Aug 1, 2020 | 09:51 AM
Rachel28's Avatar
yep i changed the front pads..thanks for your input
nynhex
May 6, 2012 09:36 PM
SExDEVIN
Car Shows, Events, and Racing
Nov 10, 2010 05:50 PM
2Legit2Fit
New England Community
Jun 17, 2010 11:53 AM
gojira
May 16, 2010 11:14 PM
dmclone
Jun 21, 2009 08:19 PM
