Oil life % question
Old Jul 27, 2020 | 02:48 PM
donlogan's Avatar
Oil life % question
Is the oil life % indicator an automated thing where it just counts the miles driven or does it actually check the quality of the motor oil?
Old Jul 27, 2020 | 04:10 PM
marmaladedad's Avatar
https://techinfo.honda.com/rjanisis/...707O00212A.pdf
"Based on the engine operating conditions and accumulated engine revolutions, the onboard computer in your vehicle calculates the remaining engine oil life and displays it as a percentage."
IME, changing the oil when the 15% notification pops up, can be at 8500 miles in my commuter (Honda Fit; 60 miles per day), vs 7000 miles for my wife's car (MDX; travels approximately 6 miles per day for work/kid-carpool).
Old Jul 29, 2020 | 04:30 PM
armcast's Avatar
^^^ what marmaladedad said. The car computes this data, it doesn't actually check the quality of the oil. The oil life indicator does a pretty good job, although if you're a bit hesitant to trust the ECU then you can stick to changing the oil at 5k-8k mile intervals (can maybe get away with 10k mile intervals) and keep track that way.
Old Aug 9, 2020 | 03:23 AM
larrymcewin's Avatar
I'm at 240k miles and found intervals around 9,000 miles. Engine is perfect. Can't tell any difference from when it only had 9 miles.
Old Aug 9, 2020 | 01:18 PM
steve37's Avatar
I usually change mine after it hits 20%...which is almost always 8-9K miles.
The oil drained looks about the same as the new going in.
Old Aug 13, 2020 | 09:09 PM
sarasube's Avatar
what about length of time between oil changes.
for example minder says 40%, but oil has not been change in over a year.
about 4k miles. not driven due to covid.
thanks
Old Aug 14, 2020 | 08:25 AM
GAFIT's Avatar
thanks
General rule of thumb for cars that aren't driven much is to change the oil once per year.
Old Aug 14, 2020 | 09:36 AM
plus one
Old Aug 14, 2020 | 11:37 AM
sarasube's Avatar
i am planning on changing oil after 1 year and 40% oil life.
but i wonder if pure synthetic oil degrade at low driven miles
even after 1 year.
thanks
Old Aug 14, 2020 | 11:47 AM
GAFIT's Avatar
even after 1 year.
thanks
Contamination is the concern. Vehicles that aren't driven as often usually contaminate the oil worse than vehicles used regularly. The water from condensation, fuel, and other contaminants from the sealants, bearings, etc go up over time.
hogwylde
Aug 15, 2015 06:25 PM
Eugene.Atget
Dec 11, 2010 07:21 PM
hogwylde
Mar 29, 2010 04:02 PM
jijifit5000
May 20, 2009 12:17 PM
db_et_ac
May 24, 2007 09:42 PM
