Brake Pad Clips
Old Aug 20, 2020 | 02:05 PM
mongerson's Avatar
Brake Pad Clips
Are the clips that hold the brake pads in place necessary?
Old Aug 20, 2020 | 02:42 PM
Red 05's Avatar
Are you talking about the steel clips that slot into the caliper bracket between the brake pads and bracket? Yeah, they are. You'll have a brake rotor stick on or wear your brake pads unevenly.
Old Aug 21, 2020 | 10:49 AM
Mister Coffee's Avatar
The return spring prevents brake drag.
File Type: pdf
Old Aug 23, 2020 | 12:05 AM
claycolvin's Avatar
Brakes
You may want to change the caliper pins at the same time. Mine were worn and I had to go at the brakes a second time to change them later. Good pins help keep the caliper from sticking. Pull the pins and examine them. The finish on mine were worn and uneven so the calipers were a bit sticky. Just something to do if your brakes are still not perfect and drag or make noises. Use silicone grease on those shims for lubrication. Silicone grease for the caliper pins too. Clay
Santiad
Sep 8, 2012 02:34 PM
Marrk
Mar 2, 2011 03:09 PM
lilcat
May 5, 2009 01:00 PM
harrywing
Feb 15, 2009 11:14 AM
djk949
May 19, 2008 02:16 PM
