2010 Power locks and Windows Issue
Old Dec 28, 2020 | 05:08 AM
Eyespy3017's Avatar
2010 base model. 65k
When I hit 60k mileage, power windows would go down after I put them up, not every time but enough to realize something isn't right. Now at 64k, the auto locks click on and off by themselves when I reach 15 mph and when I manually lock them... going to throw this tidbit in too.. certain lights, like the shift gear P R D D3 etc, work intermittently.. What is going on here!? Any other info needed? Thanks
Old Dec 28, 2020 | 05:31 PM
Frenzal's Avatar
As for the locks, I think there is a setting to be done with the remote. Need to check your owner manual or find one if you don't have one!
Old Dec 28, 2020 | 08:43 PM
Goobers's Avatar
Window channels (namely the rubber lining around the window) probably needs to be cleaned/lubed.
The rest sounds like an electrical issue... likely wires being exposed/broken.
Old Dec 29, 2020 | 10:09 AM
tyrtill's Avatar
I just wanted to back up the other two.
The reason the window goes back down is most likely its taking too much force and thinks there is something in the way such as a finger. Try silicone lube on the window slide rubber. You could also try disconnecting the motor or taking off the battery and doing an automatic window relearn by rolling the window all the way down and holding it for a second or two then all the way up and holding for a second or two.
The locks absolutely sound like the lock setting
this is from a similar year manual
The shifter lights turning on and off randomly is probably just bad connections/bulbs they are tiny little led bulbs that will slowly stop working all together. You can fix them but with the on dash gear selector display I never bothered.
4ester
Aug 28, 2016 10:31 PM
TrungLam
Mar 10, 2011 07:19 PM
Chocobo87
Sep 20, 2010 11:06 AM
dumbo717
Jul 8, 2006 01:24 PM
