honda fit cooling fan always on
Old Jan 13, 2021 | 08:26 AM
gilles_o99's Avatar
Is there a manner to stop the two fans on the radiator to stay ON all the times ? The only way I find is to put the inside ventilator OFF completely.
Old Jan 13, 2021 | 09:37 AM
Red 05's Avatar
If you've got a problem with your AC system and don't have any refrigerant yet have the AC button turned on the radiator fans will cycle on and stay on until the compressor reaches a certain pressure. Only because you don't have any refrigerant the fans never get commanded back off.
Old Jan 13, 2021 | 01:17 PM
gilles_o99's Avatar
I added some refrigerant last summer. Here in Canada, we don't need AC at this time of year. I am not sure there is sufficient refrigerant at this time because I don't use the AC. Is it possible that the fans near the radiator stays ON if the AC is OFF with a low refrigerant in the system ?
Old Jan 13, 2021 | 05:37 PM
Red 05's Avatar
If you've got the AC off but the radiator fan still goes that's above my understanding. I need to look in the service manual to understand the fan logic. Unless you've got it on defrost then the AC is on whether you pushed the button or not.
Old Jan 14, 2021 | 05:20 AM
Frenzal's Avatar
Every time you set the climate controls to vent the windshield (first 2 settings), the AC is on...
Old Jan 14, 2021 | 12:50 PM
gilles_o99's Avatar
Thanks a lot for the reply. I have the car for many years 2011 and I didn't noticed that these 2 fans on the radiator are ON when the defrost fan is used. Here in Canada we use the defrost from November to March. Is it possible to change the computer program to disable the operation of these fans if the AC is not used ?
Gilles
Old Jan 14, 2021 | 02:01 PM
Frenzal's Avatar
You'll have to not use the AC, and not use the settings that direct the air on the windshield. For that last part, it is impossible to prevent the AC from turning on, unless you modify the selector knob (there is an integrated switch that turns on the AC on these settings).
Old Jan 14, 2021 | 02:44 PM
GAFIT's Avatar
Long before I knew that cars run the compressor when on defrost regardless of temperature setting, I burnt up an A/C compressor. That was in the early '90's. After I destroyed the compressor, I unplugged the connector that runs to the compressor so that I could run defrost, but not have it try to turn the compressor.
I suggest that you either make sure there is sufficient refrigerant, or unplug the compressor. They can be damaged if run low.
Before you think it's silly to be running the compressor while blowing hot air, there's a very good reason. It is acting as a dehumidifier. You want dry hot air for defrost, not wet hot air.
Is there a reason you can't put it on defrost to clear the windshield and then switch it to vent or floor? That should fix your fan issue.
gerard6496
Jan 12, 2024 02:12 AM
Gerald Grimaldo Abellon
Jul 30, 2019 11:49 AM
boltaction
Jul 11, 2018 10:52 AM
mangosmoody
Jun 19, 2016 07:38 PM
fit4jdm
Oct 21, 2008 01:39 AM
