Front Rotor Replacement 2012 Fit with abs
Old Mar 9, 2021 | 10:45 PM
mharnisch's Avatar
Took my 2012 Fit to the dealer yesterday for the drive axle recall. An inspection of the vehicle by the dealer showed that the front pads and rotors need to be replaced. I declined having the dealer do it until I could check it out further. Thinking that I might want to do this myself, I started looking to see what pads and rotors were available at the various supply stores. Just happened to look on Rockauto.com and found something strange about the rotors. Of all the different brand rotors listed, only one brand, Beck Arnley, noted that theirs was for abs. Since my Fit has abs, I wonder if I have to be sure to choose a brand that specifies for abs, or will any rotor work. Has anyone else run into this issue?
Old Mar 10, 2021 | 05:16 AM
ikutoisahobo's Avatar
All USDM Fits have ABS. The rotor is the same, they just decided to specify it for that part.
Old Mar 10, 2021 | 10:56 AM
mharnisch's Avatar
I thought that probably abs was standard but wasn’t sure. Found it strange that one brand mentioned abs and no other brands did. Better to be safe than sorry. Thanks for the info.
max503
Jan 21, 2023 06:45 PM
TaubBaer
Jun 1, 2017 12:11 PM
pmartensen
Jan 11, 2013 06:08 PM
danger69
Jun 6, 2011 02:30 AM
pgreene
14
Nov 15, 2010 08:23 AM
