Rewiring Traction Control Button
Old Apr 14, 2021 | 08:37 PM
Gary Zimmer's Avatar
I'd like to install a control panel for controlling custom interior foot well lights, dash cam, and other accessories in the bottom left of the drivers dashboard in the spot where the Traction Control toggle button is since there's a few empty button spots.
(I know the video is from a newer model year, mine is 2012, but the spot is the same)
The
control panel would probably be something like this. control panel would probably be something like this.
What I'd like to do is replace the existing OEM traction control button with one of the toggle buttons from the control panel. I think there might be an issue because I believe the OEM TCS button is a momentary button that you have to hold down and the control panel is maintained toggle switch. Is there any easy way to get this to work? Should I consider just replacing one of the toggles in the control panel with an off the shelf momentary switch that would fit in that mount, would that work?
Old Apr 16, 2021 | 07:56 AM
Azuki's Avatar
Try looking for a fog light switch as those are usually on/off and will fit in the same slot.
Jacob1733
Apr 15, 2023 12:43 AM
Dafeex
Feb 2, 2017 07:03 PM
blackprlfit
Jan 2, 2012 01:09 AM
90crxfreak
Mar 3, 2009 03:15 AM
woginzl
Oct 24, 2005 07:22 AM
