Loss of power at high RPM acceleration
Old Apr 23, 2021 | 04:47 PM
Fitter123's Avatar
I have a Fit 2011, around 120,000 miles, and today I tried to get ahead of a really slow and bad driver. I basically went in first gear and accelerated as fast as I could. I didn't look at how high RPM went, but it was probably close to 6,000 RPM. Then for some reason the car lost power and slowed down.
My question: is it because of some device that protect the engine from red-zone RPM damage or is there something wrong with my car? The car goes smoothly otherwise; should I go to the garage and risk expensive repair?
Thanks
Old Apr 23, 2021 | 05:35 PM
Thanks
You hit the revlimit.
Old Apr 23, 2021 | 05:59 PM
Fitter123's Avatar
What is the revlimit? Is it some kind of device that protects the engine and if so, at how many RPM does it get in?
Old Apr 23, 2021 | 08:52 PM
Rick_a's Avatar
They redline at 6800. Max power is at 6600. Shift more.
Old Apr 23, 2021 | 08:57 PM
Fitter123's Avatar
I don't understand. Does it mean that at 6600 RPM there is some kind of protection for the engine and the computer stop the acceleration?
Old Apr 23, 2021 | 09:41 PM
Rick_a's Avatar
Past 6600 horsepower drops off. At 6800 it hits the rev limiter (which protects the engine from over revving).
The manual transmission cars can be over revved in a downshift...as that's a purely mechanical condition.
Old Apr 24, 2021 | 08:08 AM
Fitter123's Avatar
OK thanks! So if I understand correctly, everything is fine with my car?
Still, is it OK to rev so high a 10-year old car? Not sure if I'll do it again!
Old Apr 24, 2021 | 02:42 PM
Rick_a's Avatar
You can do it all day long. Just watch your oil consumption, as it will be higher...and it's best to shift before the limiter...because it abruptly ends your forward acceleration.
Old Apr 25, 2021 | 08:35 AM
Alco RS-1's Avatar
If you're passing someone at highway speed, 1st is the wrong choice of gear. 4th would be better -- you'll be higher up in the rev band, so will gain power, yet be no where near the redline.
Old Apr 25, 2021 | 12:32 PM
Fitter123's Avatar
Thanks. You sure about doing it all day long? Wouldn't it damage the engine long term, as the car exactly new anyway!
utsug
Sep 8, 2015 06:26 PM
Rollerboots666
Racing
May 20, 2015 05:55 PM
Alex Matthews
Nov 25, 2013 08:37 PM
x_25
Feb 13, 2012 01:58 PM
ghostfit
Jul 18, 2007 07:56 PM
