L15A7 and L13Z1 compatibility
Old May 8, 2021 | 03:46 PM
joc69uk's Avatar
Hi,
I'm asking as a complete novice to engine tuning. I'm aware of head swaps between the old H series hondas, and I'm wondering if this is possible for a L13 and L15 (both i-vtec), as over here in the UK we never got the 1.5 and I have found a sport cam (catcams) for the L15A7. I basically wanted to know if the heads are transferrable, both share the same if not similar valvetrain (16v), and both are SOHC, so is the difference just in the bore and stroke? Any help would be really appreciated cheers.
My plans in short, were if this is possible to find a L15A7 head, install the sport cam on and tune it (with a piggyback or standalone) to hopefully gain a little more power, with some small additional bolt ons such as intake, exhaust and larger throttle body.
I'm aware its possible to bolt the L15 intake chamber, just unsure about the more complex stuff, at the risk of sounding like an idiot haha
Old May 8, 2021 | 05:08 PM
joc69uk's Avatar
Upon comparing the two camshafts the difference appears to be in the timing kit https://www.parts-honda.uk/honda-car...__1100/1/22538
https://www.parts-honda.uk/honda-car...__1100/1/22414
Old May 8, 2021 | 08:00 PM
SeEnCreaTive's Avatar
Let me start off by saying I know NOTHING about head-swapping like you can on a b-series
I'm probably going to say no. I'd imagine the bore is in fact different. I can't imagine the 1.3 would be de-stroked to make for the lesser displacement
EDIT: JK it is actually de-stroked both have a bore of 73mm........ interesting
Old May 10, 2021 | 03:20 AM
hotkey's Avatar
I know of only 1 person on this forum that tried catcams sport cams. If I remember correctly, he couldn't get the motor to idle properly.
Also, as mentioned above, bore is the same, stroke is different. So, if you could, and did, swap heads, you'd still have a 1.3 motor. And if you add the sport cams....
Old May 10, 2021 | 09:24 AM
Red 05's Avatar
AND trying to run a car with a computer designed for 8 spark plugs and only use four of them. Sounds futile to me....
Old May 12, 2021 | 02:24 PM
joc69uk's Avatar
Just to clarify, this is the I-VTEC L13 so doesnt run on 8 spark plugs
Old May 12, 2021 | 02:25 PM
joc69uk's Avatar
@hotkey I was only after being able to run the cams, I'll keep these in mind however. Yes he will get a choppy idle as the powerband has been shifted. Did he have a standalone ecu? as this is required to be able to raise the idle (from memory)
Old May 14, 2021 | 08:37 AM
hotkey's Avatar
Piggyback. Dastek, if memory serves me.
Old May 17, 2021 | 10:17 AM
joc69uk's Avatar
Very interesting then. I'm aware of the Unichip, although not of its capabilities. Might end up being one of those things that you just have to take the plunge with. Would be a while however. I still wish to fit the RB1 Intake or a modified version from RZcrew first, along with a larger throttle body to suit.
Old May 23, 2021 | 10:51 AM
hotkey's Avatar
AFAIK, the most basic unit can +/- fueling and timing, but not by much. The UnichipQ is said to be more capable. As I'm sure you already know, reflash would be best. Hope it works out for you. And do let us know how it goes, for informational purposes.
H22a1Prelude
18
Dec 6, 2021 12:55 PM
Midnightfit
22
Jun 30, 2020 04:52 PM
jms
Apr 24, 2019 06:18 AM
Chav000
Jun 13, 2014 01:42 AM
ToyotaLover
Oct 28, 2007 12:03 AM
