HELP! Rough idle! 08 Fit Sport A/T
Old May 20, 2021 | 10:52 AM
JWoneswitz's Avatar
I seen this reoccurring topic, but I have to ask!
Honda Fit keeps stalling on cold starts and even worse when it is colder temperature outside!
I've replaced the spark plugs, check the coil packs, new air filter, clean the throttle body, ran a few fuel injector cleaners through it Chevron techron.
Nothing this thing idles rough and want to die if I put it in drive or reverse when it's warming up...
The mechanics I've looked at swear up and down that valve adjustments can't be that problem... So I look at them and say why can't you find another problem then. 🤷🤷🧐
Old May 23, 2021 | 05:22 AM
ikutoisahobo's Avatar
Valve adjustment. We've all been there.
Old May 23, 2021 | 08:37 PM
JWoneswitz's Avatar
You think so?
Even if it says to only adjust if it's nosie??
Thanks.
Old May 23, 2021 | 08:59 PM
Originally Posted by JWoneswitz
You think so?
Thanks.
Yes. If the valves are getting too tight they also don't make any noise. In fact, my GD and GE have pretty much sounded the same before and after the valve adjustment.
Also ensure that spark plugs are gapped right and that the coil packs that you used are OE Hitachi or Denso only.
Old May 23, 2021 | 10:11 PM
JWoneswitz's Avatar
Okay, 3 shops tell me I'm mistaken. That I'm dumb founded and don't know what I'm talking about!
I asked to look at the Live data of the Fuel trims and they wouldn't do it.
Old May 23, 2021 | 10:19 PM
Most shops don't even know that you should perform a valve lash adjustment on these engines. Even some dealers are confused until they look it up.
The GD Fit is one of the easiest to do an adjustment on. Unlike the 2nd gen GE you don't have to worry about taking the cowl off.
Old May 23, 2021 | 10:22 PM
JWoneswitz's Avatar
What feeler gauge (metric) did you use?
Old May 23, 2021 | 10:29 PM
pretty much exactly this one but I picked it up at AutoZone
Amazon Amazon
The bent tips are a must to get the correct feel.
Old May 24, 2021 | 12:23 PM
JWoneswitz's Avatar
Last question....
Do I Have to remove the spark plugs before adjustment of the valves? Some I read say yes, some I seen don't.. what's the Proper way?
Old May 24, 2021 | 12:29 PM
JWoneswitz's Avatar
Last question....
Old May 24, 2021 | 01:42 PM
Pyts's Avatar
removing spark plugs will make it easier to rotate the engine internals via by rotating the harmonic balancer. no compression when plugs are removed. if you remove them, make sure you re-torque em to 20 ft.lbs.
Old Feb 4, 2022 | 02:42 PM
Stephane's Avatar
I had this issue and tried a bunch of things. I did valve adjustment at the same time as replacing the ignition coil pack and that seemed to do it.
I had previously replaced the spark plugs, cleaned 02 sensor, replace map sensor. The spark plug replacement seemed to alleviate the issue but only for a few days.
You might have just 1 or 2 bad coils which you can swap around and try new ones to identify them but I just replaced all 4 to be safe.
Lastly I had this issue for the better part of a year before the car ever threw and engine code. Forget the code but it was a misfire code and told me the cylinder.
Ymmv but maybe something to check if you have exhausted other options.
Mike Runge
Jun 11, 2017 11:46 AM
Daghain
Aug 24, 2014 04:37 PM
BrianKearsey
Apr 14, 2014 06:20 PM
msuh27
Sep 1, 2013 12:20 PM
cheanko
Dec 12, 2012 02:34 PM
