AC won’t turn off
Old Jul 12, 2021 | 10:46 AM
Mickeynol's Avatar
AC won’t turn off
Hi I have a 2010 Fit and the AC will not turn off. The only way I can get it to turn off just take the relay out for ac clutch, I checked all three of them under the hood and I are fine I even swap them around to see if that would help still the same thing. I also checked the switch and it’s ok The clutch stays engaged even with a switch disconnected. Any help or suggestions would be appreciated thank you
Old Jul 12, 2021 | 12:17 PM
Brain Champagne's Avatar
Is there any chance you have it set to defrost or defrost plus heat? That runs the A/C even when it's switched off.
Old Jul 12, 2021 | 12:25 PM
Mickeynol's Avatar
No I don’t but thanks for the reply. It doesn’t matter where anything is set at it still stays on
Old Jul 13, 2021 | 10:53 PM
claycolvin's Avatar
Ac
Does the AC switch stay illuminated? If it won't shut off you need a new ac switch in the dash. Best of luck. Clay
Old Jul 13, 2021 | 11:03 PM
Mickeynol's Avatar
Switch
thanks for the reply the light does not stay on and I actually took the switch out and the compressor ran anyway. I’m thinking it must be the switch in the mode selecter
htewam
Sep 25, 2024 03:26 PM
Mickeynol
Aug 3, 2022 10:44 AM
bobvila
Jun 9, 2021 07:00 AM
Uglycasanova
Jun 11, 2020 02:56 PM
ASTEIN
Jul 13, 2010 01:20 PM
