Random vibration and low hum noise once in a while.
Old Sep 15, 2021 | 11:20 PM
fuego34's Avatar
Exclamation Random vibration and low hum noise once in a while.
2012 @127k mi, automatic. I haven't changed the spark plugs yet. Brakes were done at@80k mi.
I get this random vibration and low hum noise while driving once in a while, it's hard to re-create. It seems If i drive it hard it will start. Driving hard as in floor it once or twice and brake hard. Next start cycle nothing, everything works fine until it randomly does it again. I try to keep in mind what I did to get this noise but no luck recreating it. I don't konw what to explain to the mechanic if I can't get consistent way to recreate it.
Any thoughts?
Old Sep 19, 2021 | 10:16 PM
fuego34's Avatar
Bump
Anything? Mechanic can’t replicate it and it happens once in a while.
Old Sep 20, 2021 | 12:03 AM
Pyts's Avatar
Where's it coming from? Are you sure it doesn't trigger at a certain rpm or speed? Do brakes cancel said noise out if reapplied? There was another thread on noise quite recently you could check for ideas.
Old Sep 20, 2021 | 09:10 AM
fuego34's Avatar
I got it again this morning.
  • Car @2K rpm
  • It starts up is around 50+ mph
  • Certainly when the car is rolling
  • Definitely not engine at this point bc I can stop the car and no shakes or noise, has to be in the wheels somehow.
  • Braking cause additional shakes, and they also seems a bit more squeaky than usual. also noisy if i let of them and press in at a light.
  • This brake related?
Last brake job was at 75-80k miles now car is at 126k, am I overdue?
Old Sep 20, 2021 | 04:42 PM
Pyts's Avatar
The car shakes/vibrates when braking?
If so, yeah, brakes need attention. Vibration when braking is likely due to warped rotors.
Old Sep 23, 2021 | 09:25 PM
fuego34's Avatar
Going to take it in and will update here.
Old Oct 9, 2021 | 10:40 PM
fuego34's Avatar
BRAKES! Drives like new after I got them replaced.
Cordizzle4life
Oct 8, 2012 04:21 PM
ihuixaya
Sep 18, 2012 02:55 AM
fujisawa
Aug 7, 2012 05:52 PM
Eamper
Mar 11, 2011 07:27 AM
NBPturtle
May 29, 2008 09:52 AM
