Noise, won't go away, Tried a lot!
Old Oct 3, 2012 | 09:16 PM
Cordizzle4life's Avatar
Hey guys, I'm having a bit of an issue.
First, I heard a noise coming from my engine after I change the weight of my oil (5w-30 instead of 5w-20), it's like a "tick tick tick tick tick" but, when I put my foot on the pedal to 1500-2000 rpm, it turns into a sort of growl, as if the tick is speeding up.
I read on here I need to get my valves adjusted, so I took it to the dealer, paid $171 to get them adjusted, drove it home...IT WAS STILL THERE!
So, I thought: "Maybe the platinum spark plugs I put in were no good" (I had NGK platinum, even though the car came with Denso Iridiums). So, I swapped them instead for a simple, Bosch copper plug and the noise has decreased a bit, but is still there.
Could I be hearing a normal noise, like the timing chain (all other cars I've driven are belt driven, so I could just be hearing a difference in driving mechanisms)?
Anything you guys could help me with would be awesome, I just want this noise to stop....every time I notice it I feel like I'm being a hypochondriac with my car.
Thanks!
Corey
Oh, one last thing. The noise is either unnoticeable in the higher rpms (2500-up) or goes away completely.
Old Oct 3, 2012 | 10:32 PM
sean5995's Avatar
cough cough heat shield cough cough
Old Oct 3, 2012 | 11:22 PM
doctordoom's Avatar
Supervillain
Video of noise?
Old Oct 4, 2012 | 12:11 AM
Really? I was thinking something was rattling too but I wasn't sure. What could I do to fix this? Is there a thread already here?
Old Oct 4, 2012 | 12:17 AM
I've been reading and I'm going to check the heat shield. Thanks for that suggestion!
Dead thread at this point!
Old Oct 4, 2012 | 08:41 AM
NIGHTHAWKSI's Avatar
the valves/injectors on the fit are noisy.
im gonna say the noise is in your head since your "looking" for somthign wrong. its probly been there the entire time.
Old Oct 8, 2012 | 03:25 PM
I was thinking that, but my friends can hear something weird too, even when I haven't said anything to them. But I'm pretty sure it's a heat shield, because it hasn't happen consistently enough for it to be a valve issue, it comes and goes.
Thanks for the input though!
Old Oct 8, 2012 | 04:21 PM
TPColgett's Avatar
I have a similar ish noise as well.. I also adjusted the valves, changed oil, and don't have a heat shield on my header... At this point I have chalked it up to noisy injectors and drive train
flyingby
Mar 5, 2025 10:45 PM
danielmorrison
Sep 26, 2016 09:13 PM
Mister Coffee
Nov 27, 2014 10:29 AM
ihuixaya
Sep 18, 2012 02:55 AM
