So my engine is done for
Old Dec 22, 2021 | 07:00 PM
Blackfitge2's Avatar
Today my 2009 fit manual trans' engine died via a bearing going out and a valve seal dropping a new l15a is easily 7k plus and I am seeing k20 engine for way cheaper what is the market like right now which engine is more reliable I also live in the mountains. So more power would be incredibly helpful. What is more cost effective right now.
Old Dec 22, 2021 | 08:15 PM
petelite's Avatar
How about a used engine? A K20 swap will never be cost effective.
Old Dec 22, 2021 | 10:27 PM
There’s no way an L15A is $7000 and a K20 much less.
Old Dec 22, 2021 | 10:45 PM
JingJangJoe's Avatar
With that kind of costs for an engine............Time to change car?
Old Dec 23, 2021 | 06:39 PM
fujisawa's Avatar
Used sounds right. The k series has never been "drop in", that's an actual project. Not like the d/b series+ecu was.
.. And if it's not hard, then let me know, and I'll a go buy a k20 to put in
Old Dec 24, 2021 | 08:00 AM
knope's Avatar
How? Did it rev over redline or something?
Old Dec 24, 2021 | 06:22 PM
GAFIT's Avatar
I bought a running 70k mile motor at a salvage yard for $500. L15A1 and not the L15A7 in a GE, but they are the same price. Check car-part.com, put in your year, select engine, and you'll see what's in your area. Around me I see GE motors for between $250 and $650.
Old Jan 3, 2024 | 01:34 PM
guywire's Avatar
Hey, how did that new Used engine work out for you? . I have a 2009 sport fit mt that’s using 1 qt oil/800 miles and trying to explore my options. Seems like 7 k
is too much to put in my 225 thousand mile car, even though I like it.
Old Jan 3, 2024 | 02:39 PM
Drew21's Avatar
Not sure where everyone keeps getting the $7000 for a Honda Fit engine, but as GAFIT said, you can do much better than that with a tiny bit of searching.
If you haven't done so, it might also be worth your time to figure out why your car is using so much oil. Is it leaking? Maybe a new gasket or seal could fix your problem.
Blackfitge2
Dec 24, 2021 12:36 AM
SLIPNFIT
Jun 8, 2021 04:34 PM
willy65000
May 25, 2017 06:57 AM
MMurray
Oct 8, 2010 03:49 PM
Injundon
Oct 9, 2007 02:26 AM
