Replace stabilizer bar link??
Old May 19, 2022 | 02:04 PM
JDFit's Avatar
Any benefit in replacing the stabilizer bar link with a MOOG K750381 if the old link still works (About 9 years old now)? Does it help the ride, or will there be no difference?
Thanks
Old May 19, 2022 | 02:29 PM
GrE8_Fit's Avatar
It seems the popular opinion is to replace them frequently. They do wear out, even if they feel fine. But I'm sure someone with more experience will have a better answer.
Old May 19, 2022 | 04:12 PM
Frenzal's Avatar
If you have no sound and they are not broken, why replace them?
If you replace, I suggest the "problem solvers" from Moog. They are beefier and have grease fittings so you can lube them.
Have them on my Fit and Accord. Was replacing the OEM ones quite often (on the Accord), until I bought the Moog. Since then, no problem! They are also quite cheap from Rock Auto.
Old May 20, 2022 | 02:05 PM
JDFit's Avatar
My original question mentioned the MOOG K75038. Is that the problem solver or is it a different part?
Old May 21, 2022 | 10:28 AM
Frenzal's Avatar
It would be Moog 750381. 22 $ CAD from Rock Auto (should be even less in USD).
Old May 21, 2022 | 11:44 AM
mobby_6kl's Avatar
I wouldn't bother if they don't make any clunking noise. There's no way you'll be able to tell any difference.
ForestMusic
Jan 6, 2017 07:38 AM
appleica
Dec 6, 2012 03:26 AM
FELIXY69
Feb 22, 2008 03:56 PM
ldweng
Oct 8, 2007 03:41 AM
michaelfit84
Jul 10, 2007 01:31 PM
