Immobilizer chip on key?
Old May 23, 2022 | 05:49 PM
johnblazemclane's Avatar
My 2013 Fit Base model key is falling apart. I tried digging through all the threads but none answered my question. I don't see an "RFID" chip in here just the part labelled 72147-SWA-A0. So does that mean I don't have an immobilizer and could just swap the key blade and electronics to something
like this like this
and be good to go? My instincts says yes and that I'm asking a really dumb question so thanks in advance.
Old May 23, 2022 | 06:20 PM
56chevydan's Avatar
You do have an immobilizer key.
Personally I think you're overthinking this a little too much. If all functions of your current key work but your plastic key case is broken, that replacement key case is what you need. If functions of your current key don't work, this basic key case isn't going to make the key work any better.
Place your cursor on the upper left part of the ad you attached, and it basically answers the question I think you're asking. It basically instructs you how to remove the working parts of your current key, and how to install them in their replacement key case. Good luck.
Old May 23, 2022 | 06:24 PM
Thanks! I was definitely over thinking it.
Old May 23, 2022 | 09:56 PM
howarejew's Avatar
Check your original key. Some of them have the transponder chip on the plastic case and some have it integrated into the motherboard of the electronics. (Photo #4 of that amazon link)
Old May 23, 2022 | 10:11 PM
Yeah I think that's what was tripping me up. Some videos I saw had a separate chip inside on the top left of the key. Mine doesn't so I'm assuming it's all integrated to the motherboard with the lock/unlock/panic buttons. Went ahead and ordered the kit from amazon.
reference image
Old May 31, 2022 | 03:25 AM
Worked like a charm. Took a few minutes to swap everything over. Got a silicone cover too, maybe protect it a bit from drops.
Old Jun 3, 2022 | 12:16 PM
2012FitFan's Avatar
Does the 2012 Honda Fit have the chip integrated in the motherboard? Dealer wants to sell me entire thing, with blade. I’d rather try doing it myself, if it’s just a shell replacement. Just want to make sure chip is integrated and not separate. Thanks.
Old Jun 3, 2022 | 12:20 PM
For my 2013 it was integrated. I'd assume the same for a 2012.
Old Jun 3, 2022 | 12:23 PM
2012FitFan's Avatar
Thanks, John.
Did you order the shell from the link above? Where did you get the silicone cover?
Thanks again!
Old Jun 3, 2022 | 12:30 PM
Thanks, John.
Thanks again!
Yup ordered that exact one. The silicone cover was on Amazon too, just search silicone Honda fit fob cover. I think it showed as a recommended item when I got the new shell.
Old Jun 3, 2022 | 12:33 PM
2012FitFan's Avatar
Thank you, sir!
Does the new shell feel sturdy enough to you, when turning over the key?
Old Jun 3, 2022 | 12:36 PM
Thank you, sir!
Honestly feels more sturdy than the OEM key.
Old Jun 3, 2022 | 12:40 PM
2012FitFan's Avatar
Thanks for all your help! 👍🏼
Old Jun 3, 2022 | 01:30 PM
howarejew's Avatar
Open it up and take some pics
Old Jun 3, 2022 | 01:36 PM
AirborneRATT's Avatar
Cool
My 2013 Fit Base model key is falling apart. I tried digging through all the threads but none answered my question. I don't see an "RFID" chip in here just the part labelled 72147-SWA-A0. So does that mean I don't have an immobilizer and could just swap the key blade and electronics to something like this and be good to go? My instincts says yes and that I'm asking a really dumb question so thanks in advance.
That will work perfect. I did the same thing for my key. Works like a champ today. You might as well install a new battery in it too while you have it open.
Edit: Yes it does have an immobilizer but that is all built into the circuit board of the key and you're not modifying it in any way. You're just swapping the nice tidy plastic cover. It really is as easy as one screw. I will add that the new shell that you're buying is not the same high quality as the original. I'm about two years into mine and I may need to swap it again in another year or so.
Old Jun 4, 2022 | 11:14 AM
Mister Coffee's Avatar
If you will provide the information for a correct replacement battery, I will throw one into m Amazon cart.
Old Jun 4, 2022 | 11:20 AM
2012FitFan's Avatar
CR1616 for our key fob. :-)
Old Jun 4, 2022 | 12:12 PM
Thanks, amigo.
Old Jun 4, 2022 | 01:49 PM
2012FitFan's Avatar
Thanks, amigo.
My pleasure.
I just ordered a shell and a couple of the silicone covers that John got. Can’t hurt, especially when dropping keys.
Old Jun 5, 2022 | 10:59 AM
My pleasure.
Is it
this this
one?
