09 FIt None of the windows work.
Old Jun 15, 2022 | 04:24 PM
crew2139's Avatar
Question 09 FIt None of the windows work.
Have an 09 Fit Sport. None of the windows work. Stuck on up position. Ran direct wire from battery to front passenger, and both rear regulators. All 3 work. Connecting power and ground, they go down. Reverse polarity, windows go up. Didn't know how to do this test on the front driver side regulator. It has 6 pins. A bit more complicated. But I have a feeling that it also works. Checked the relay. It is good. All fuses are good. Traced all wires/harness from all regulators to the door switches, and from door switches to the master switch connector, and all wires from master switch connector to under the dash connectors and the fuse box. No broken wire. Bought 2 after market master switches (2009-2013 Honda Fit). Neither worked, including the car's original master switch. Have ground on pins 11 and 12, and power (12V) on pin 4 of the master switch connector. The door lock button works. Doors lock and unlock. On the schematic one of the pins of the relay goes to MICU. Does MICU have anything to do with it? Running out of ideas. Any suggestion? I'll be grateful.
Old Jun 26, 2022 | 07:09 PM
Pep's Avatar
Pep
Did the switches getwet at all recently?
rocksnap
Jul 27, 2024 01:59 PM
abracadabra
Aug 4, 2019 11:35 PM
Cordizzle4life
Feb 10, 2019 09:58 AM
cakacon
Dec 5, 2018 10:18 PM
Codger01
Jun 1, 2013 09:13 PM
