does anyone think this makes sense - headlights
Old Nov 13, 2022 | 01:15 PM
inkan's Avatar
so when i have the regular halogen lightbulbs in the headlights, the low beams are both on, but when i turn on the brights the right blinks for .2 seconds then goes out. left stays on bright and then switching back to low beams they both turn on again
i switched to LEDs and now on low beams the right headlamp switches on for .2 seconds and goes out. left stays on. when i turn on brights both left and right stay on
anyone had this problem? or just a wiring issue?
Old Nov 13, 2022 | 07:06 PM
James Butler's Avatar
To check bulbs try swapping them from left to right side and then try again. Could be bad high beam filament in right side. Let us know what you find.
Old Nov 15, 2022 | 02:50 AM
kostby's Avatar
It's possible that the issue you're having with the standard halogen bulbs is a bad filament one of the bulbs.
A properly functioning halogen bulb shouldn't go out after .2 seconds on high beam.
The other issue is that "headlight replacement" LEDs may ALSO require an additional load resistor pack on each LED to function properly in a car that wasn't originally designed for LEDs.
I'm not recommending this vendor or these bulbs, because I didn't buy these products from this vendor, but a quick search brought this link containing both H4 LED bulbs and the optional add-on resistors to illustrate what I'm talking about.
I've edited the link below so you'll have to replace the word DOT with a . and remove the added spaces around the word DOT if you want to use the link.
https://www.superbrightleds DOT com/h4-led-fanless-headlight-fog-light-conversion-kit-with-compact-heat-sink-4-000-lumens-set-cool-white
CMDV
Mar 5, 2022 01:02 PM
qazwsxedc
Mar 21, 2021 11:09 PM
dsl
19
Oct 14, 2014 04:14 PM
rsawn
Mar 18, 2012 09:23 AM
inkeye
Nov 5, 2010 02:14 PM
