Horn doesn't work. Can't get out of Park.
Old Dec 4, 2022 | 03:23 PM
Ryu69's Avatar
Hi everyone. I have a 2009 Honda Fit Sport.
I recently noticed my horn doesn't work, either from arming the car and pressing the horn directly. Also i cannot get the car out of park. When I press the brakes my brake lights do not go on either. I was wondering has anyone else experienced this?
Thanks
Old Dec 5, 2022 | 06:33 AM
Frenzal's Avatar
Your problem for the brakes and not able to get the car out of park is probably your brake switch.
As for the horn, you should check if you get voltage to the horn terminals. If you get voltage, your horn might be shot.
Old Dec 5, 2022 | 01:37 PM
Ryu69's Avatar
Thanks for your reply. I did some more digging on google and some suggest to #24 fuse might have blown. I am going to try to check that and hopefully that is the issue.
Old Dec 6, 2022 | 04:29 PM
Ryu69's Avatar
So I tried changing the #24 fuse for Stop/Horn, but that didn't work as it did for some other people. Going to get it towed to the shop and hopefully it won't be too expensive to fix.
Thanks
FITMugen
Jan 22, 2010 11:33 PM
ckdk1
Mar 1, 2009 08:00 PM
gummyrabbit
Nov 23, 2007 03:30 PM
mute
Apr 1, 2007 10:53 AM
benfal2001
Dec 9, 2006 01:45 AM
