Super rare / random crank no start ... eventually starts
Old Jan 1, 2023 | 09:40 AM
ANGST's Avatar
2009 Honda Fit Sport AT . 150K miles
2 years 10K miles ago my Fit would not start , it would crank and crank , it started to sound like it was cranking slow and I hooked up the jumper cables . Cranked and cranked. Eventually it started . Figure 10-15 minutes of on and off cranking the engine.
It was November , the car had been sitting for 3 or 4 days.
Fast forward to a week or so ago , same thing. Car had be sitting for 3 days , but was started a couple times to move it . It belongs to my son now , and it took him 10 minutes of trying before it would start.
No issues since , and no issues after the first time it happened to the second . No CELs , Strong gas odor when it finally started , which I imagine was from all the fuel pumped into the engine when cranking.
Any ideas ? This is impossible to troubleshoot , lol .
Old Jan 1, 2023 | 01:30 PM
GrE8_Fit's Avatar
Fuel problem maybe. Dieing pump or a clog somewhere?
Old Jan 1, 2023 | 03:58 PM
Pyts's Avatar
I had a no start maybe a month back? There's a lot of factors to starting, and failure could be a cumulative effect: a number of things not ideal plus x factor. But. for me, my fault was during winter and a solution assuming winter gas to be the fault wound up working for me.
Next time, floor the gas pedal while cranking.
Here's a readable courtesy of car and driver. I don't think it listed the solution I'm offering.. I ditched that link way back when because the dude literally had no legitimate argument. Yet it worked for me
I knew my plugs were good, valves adjusted. My fuel pressure regulator may be wearing out (potentially indicated by clatter on cold start during low temp weather) but I could hear the pump pressurizing lines when I flipped the key to On II. Ran two scanners on it and got nothing. No CEL, no reason for failure. I keep my GE pretty tight and greasy.. so the no-start had me pretty upset.
Give this solution a shot next time. Maybe I'll hear back from yuh in two years.
PS: I recall reading from an early 90's Chevy shop manual twice the bulk of a dictionary that flooring the gas when cranking was used to cut fuel and clear flooding. I think I did read in the Fit's SM that it serves the same function in our application. It wasn't listed as purposed for flooding, I think it just said that if you crank it floored, it cuts fuel as a safety thing..
Old Jan 2, 2023 | 09:38 AM
Mister Coffee's Avatar
That's what we did in my day. On engines with carburetors.
Just sitting here trying to remember the last time I flooded an engine with fuel injectors. Maybe it will come to me after a cup of coffee . . . .
Old Jan 2, 2023 | 11:04 AM
zcargo's Avatar
FWIW,
Honda Fit User's Manual, Page 216. Steps 5 & 6, specifically.
patm95
Oct 31, 2023 11:47 PM
TheDadMan
May 29, 2022 07:55 AM
SilverEX15
Mar 26, 2018 07:51 PM
Coconuts
Dec 11, 2012 08:13 AM
faral
May 6, 2011 09:31 AM
