Automatic transmission 2009 fit sport replacement
Old May 20, 2023 | 07:51 PM
atHONDAFIT's Avatar
Trying to replace the trans in my girlfriends fit it’s a sport model 2009 and I bought a replacement off working fit but it isn’t a sports model
i threw it in and locked up the crank took it apart motor spins freely trans is on the ground looks fine. My question is are these compatible as well as is there a specific way to line it up I’ve searched high and low couldn’t find anything was hoping someone who’s better informed and not as ignorant as me could help. Anything helps any suggestions ANYTHING I need this car off my driveway and running.
Old May 20, 2023 | 11:42 PM
56chevydan's Avatar
For the most accurate info available, other than a Honda dealer, call a wrecking yard near you. Ask them to check their interchange guide for fitment between base and sport..
Old May 21, 2023 | 02:54 AM
mykizism's Avatar
Sport and Non Sport automatics should be the same transmission.
TIGHT-FIT
Aug 23, 2017 11:56 AM
pln101
Nov 9, 2016 10:25 PM
canuck901
Dec 18, 2010 02:09 PM
jhp7395
Oct 25, 2008 11:35 PM
HondaFitted2007
Sep 18, 2008 02:16 AM
