Slave Cylinder Fitting
Old Jun 26, 2023 | 07:55 AM
m23's Avatar
m23
The hydraulic line leading to the bottom of the clutch slave cylinder screws into a larger nut (14mm I believe), this larger nut is connected directly to the bottom left of the slave cylinder. When I put a wrench on it, this larger nut wobbles or moves in relation to the slave cylinder, is it supposed to do this or should it be rigidly fixed to the slave and thus need tightening?
Old Jun 28, 2023 | 03:41 PM
mkchiu's Avatar
SMC is #8 (on left) in below diagram. Are you talking about the shift fork lever side on #8's right ending in a ball?
Old Jun 30, 2023 | 06:49 PM
m23's Avatar
m23
It's #10 on the bottom left of the slave cylinder in the diagram. It appears to be some type if flexible joint, it moves when I push on it, and only spins when I try to tighten it.
Old Jun 30, 2023 | 10:41 PM
mykizism's Avatar
That's normal
Old Jun 30, 2023 | 11:20 PM
mkchiu's Avatar
The top of #10 is similar to a quick connect with an o-ring seal. It will wobble a little.
The bottom of #10 is threaded and should fully tighten onto the threaded pipe below.
hyperfit
May 25, 2016 05:47 PM
Mister Coffee
May 12, 2015 12:24 PM
trancedsailor
May 19, 2009 11:33 PM
HB1320
May 5, 2009 11:51 AM
Abeness
Jul 8, 2005 05:40 AM
