07 Fit Sport Squealing AC Noise on Startup
Old Sep 8, 2023 | 08:01 PM
kikisgarden's Avatar
Smile 07 Fit Sport Squealing AC Noise on Startup
Hi! Just got my first ever fit - a 2007 with 198,000 miles on it. My car unexpectedly broke down while I was in between jobs and I needed a decent budget car before I am able to buy something a little nicer for myself. It had a brand new alternator and AC when I bought it, along with new tires, sway bar links, and everything else seems to be in good condish!
However, when I start it and the AC is running, it makes a squealing whirring sound for about 30 seconds to a minute or until the engine warms up and then the noise stops for the rest of the drive. This noise only happens when the car is in drive or reverse. Also, if the car is started and the AC is not on, it makes no noise. Any idea what could be causing this?? Thank you!!
Old Sep 9, 2023 | 09:35 AM
Frenzal's Avatar
Is your belt and tensionner good?
Old Sep 9, 2023 | 09:55 AM
Yeah I wondered if it's a belt/tensioner issue! I tried to have my dad take a look at the belt, but it's such a compact engine that he had a hard time accessing it. I'll probably just have to take it into a shop.
Old Sep 12, 2023 | 07:55 AM
LeraKlocko's Avatar
The squealing whirring sound that occurs when you start your 2007 Honda Fit with the AC running in drive or reverse could be related to a loose or worn AC compressor belt, a faulty AC compressor clutch, or an issue with the idler or tensioner pulleys. This noise likely occurs due to increased load on the AC system when the compressor engages, and it may dissipate once the engine warms up. It's advisable to have a mechanic inspect and potentially adjust or replace the belt, check the condition of the AC compressor clutch, and examine the pulleys to resolve the issue and prevent further damage to your car's AC system. If you want to earn money then you can visit https://casinosanalyzer.com/online-casinos/krikya.com website link where you will find Krikya casino reviews which is a place where security and fun are a match made in heaven. Krikya Casino’s ability to adapt to different devices as well as their strict security standards, as approved by Curacao e-gaming, creates a safe and fun gaming environment.
Lanes
Jun 7, 2023 11:13 PM
pattcaroline
Sep 11, 2021 06:05 PM
Rdputtin
Jun 17, 2020 03:27 PM
angryhippie
Apr 21, 2016 10:30 PM
fit-aficionado
Sep 8, 2009 07:49 PM
