Honda Fit 2009 / CAR DIES, only changed the belt
Old Jan 10, 2024 | 03:27 AM
Honda2009Mt's Avatar
I have a Honda fit 2009 and the car dies. Only changed the timing belt.
I checked all sensors and nothing. Now I am debating if it’s a pulley because crankshaft pulley also controls the power steering. Any help last option would be to tow the car.
- Cant accelerate
​​​​- checked spark plugs and coils good
- battery is good
- replaced starter other one was old
- has new timing belt
Old Jan 10, 2024 | 07:41 AM
Frenzal's Avatar
No timing belt on the Fit.
No hydraulic power steering on the Fit.
At least that's cleared.
Old Jan 10, 2024 | 12:16 PM
Timing belt
have you experienced this behavior? I watched thousands of videos and nobody seems to have this issue.
i also checked fuel pump and fuel injectors and that is not the case.
Old Jan 10, 2024 | 12:54 PM
Frenzal's Avatar
No.
But it is impossible you have a new timing belt as the Fit does not have a timing belt.
Also impossible that a pulley controls the power steering as it is electric on the Fit.
Old Jan 10, 2024 | 01:02 PM
Honda fit does have a belt
No.
I just mentioned that the power steering is electric. I suggest you do some digging about pulleys they control numerous things.
yes the Honda has a belt. Also called the serpentine.
Old Jan 10, 2024 | 04:08 PM
Frenzal's Avatar
Of course they have a serpentine belt! But no timing belt. Very different belts...
The serpentine drives the alternator and A/C.
One thing to check: is your connections to the battery good? Well tightened? Are your ground connections good also?
Old Jan 10, 2024 | 05:45 PM
Pyts's Avatar
This has been a pleasure to read. Sub'd!
Old Jan 11, 2024 | 02:18 AM
Serpentine belt replaced car dies
connections are good but I heard these cars are faulty on electrical harness. It is a small engine so I’m looking into that.
so far the belt and pulley make a squeal noise and car turns off.
Old Jan 11, 2024 | 07:48 AM
GrE8_Fit's Avatar
Sounds like a pulley bearing is bad/ seized and the belt is slipping. Check your tensioner, maybe.
Old Jan 12, 2024 | 02:44 AM
Tensioner pulley
yes sir I’m going to check all the pulleys but I am concerned about the tensioner, idler, and crankshaft.
i have no idea why another pulley would fail but if I get the chance I’m going to replace most sensors like the crankshaft sensor and some pulleys.
Dammit belt lol
Old Jan 13, 2024 | 07:19 PM
56chevydan's Avatar
My 2 cents worth, start off by removing the serpentine belt again and check the belt tensioner to see if it's starting to sieze or turns roughly. If it were me I'd just replace it and be done with it. They're priced reasonably and they are under stress all the time the engine is running by taking up the slack in the serpentine belt.
Old Jan 13, 2024 | 09:42 PM
Belt tensioner
Yes that’s exactly what I was thinking replacing the belt tensioner since I replaced the belt. I read some threads and it looks like many tend to replace the tensioner as well.
yea there not that expensive just save yourself from a hassle experience lol thanks man I’ll keep updating
Old Jan 15, 2024 | 04:22 PM
SiXiam's Avatar
It is a common issue that the serpentine belt is installed wrong and not on all the pulley wheels. I installed mine from the top like 3+ years ago. It was a pain and I wished I just took off the wheel and plastic cover.
Old Jan 17, 2024 | 12:46 AM
Squeal noise from tensioner
yea the belt is on perfectly I have even reversed and driven forward. The real problem is the car turns off.
when I get the chance I’m going to remove the tensioner and check for other pulleys to replace. Possibly even buy a OEM belt if needed.
Old Jan 17, 2024 | 06:03 AM
Frenzal's Avatar
I don't see why the belt would be responsible for the car dying...
If your battery is good, you can even run the car without the belt for a short period (of course it'll drain the battery as the belt moves the alternator, which is used to charge the battery).
In the long run, the belt is needed for the alternator and a/c. So unless your alternator doesn't turn and the battery drains and dies, the car shouldn't turn off because of the belt. Unless there is something I don't understand.
Old Jan 17, 2024 | 04:02 PM
drbyers's Avatar
That's what I would do. It's a relatively cheap fix and depending on how old your car is, it might be time to change the pulley anyway.
You can easily check to see if the pulley bearing is seized by removing it and placing your thumb through it and spinning the pulley wheel. If it spins freely then it's not seized. If it it doesn't spin or spins roughly then it's definitely time to swap it out.
Old Jan 17, 2024 | 05:32 PM
Belt tensioner
yea I don’t understand neither but there is a squeal noise and I have to check the belt tensioner now.
a lot of people seem to replace this pulley and hope for the best.
Old Jul 16, 2024 | 04:51 AM
Removed old tensioner
Just making time to fix the car this summer ordering new tensioner will update soon when I get it installed, it’s not to difficult to replace I hope the car starts this time.
Old Jul 16, 2024 | 06:56 PM
SiXiam's Avatar
It has been six months. Has the car still had the problem all this time?
Old Jul 16, 2024 | 07:20 PM
Parked car
yea I parked the car and the car is not to reliable I had to work and work around my home with other important duties, but so far this car might have a lot of issues because the spark plugs go out and even the coils.
