2011 Fit Sport (MT) Condenser Fan not working.
Old Aug 14, 2024 | 07:50 PM
Senicova's Avatar
I recently replaced my AC compressor which was bad since owning the vehicle used, refilled the coolant and all works as it should except the condenser cooling fan is not working.
I checked the relays and swapped it with the radiator fan relay and it still doesn’t work.. the radiator fan worked still so it’s not the relay.
I all ready purchased but haven’t received the whole fan assembly.. has anyone else had the fan motor blow out.. or is it some other problem potentially? I hope I didn’t buy the part and it still wont work.
Old Aug 15, 2024 | 07:18 PM
Senicova's Avatar
UPDATE. I put the new fan in and it still doesn’t work.
The resistors are fine, the fan is good.. still doesn’t run.
Now what are my options?
Old Aug 16, 2024 | 05:19 PM
claycolvin's Avatar
Fan problem
Check the wiring to the fan. The reading should be the same for both fans right? The two fans on the radiator are the only fans that I know of.
uRabbit
Aug 15, 2024 08:36 PM
scarvalho
Oct 26, 2020 11:50 AM
Gerald Grimaldo Abellon
Jul 30, 2019 11:49 AM
mangosmoody
Jun 19, 2016 07:38 PM
fit4jdm
Oct 21, 2008 01:39 AM
