Low maf gs readings
Old Oct 9, 2024 | 09:47 AM
Herut's Avatar
Low maf gs readings
On my 2012 Jazz. CVT 100K KM, I'm getting MAF readings of 1.4 gs to 1.6 gs at idle. I assume these are way too low, but can anyone tell me what the correct maf/gs should be at idle? Also aside from bad MAF sensor is there anything else that will lead to this problem?
​​​​​​( I understand that vacuum leaks could be the culprit as well, but before spraying carb cleaner all over the place and not really knowing what I'm doing, i wanted to try and focus on whether the MAF might be bad.) Thanks.
Tslipknotm6
Mar 4, 2023 09:57 AM
Wreck Ignition
Aug 20, 2015 07:23 PM
im the fit
Oct 13, 2009 08:49 AM
quangalang
May 8, 2008 03:26 AM
skyludeboy
Feb 9, 2008 11:01 AM
