Bad maf sensor at 115k
Old Feb 27, 2023 | 08:53 AM
Tslipknotm6's Avatar
Hi all. 2015 fit here with 115k miles. I've owned it since new. Do all my own maintenance. About a month or so ago I noticed a pretty big drop in mpg. Usually around 38-40 down to 30-32. But the car still seemed to be running mostly ok. Idle was a little rough but not terrible. I have a cheap scan tool and when I hooked it up my long term fuel trim was running lean by about 15%. Not enough to throw a cel....
Ran through a bottle of techron and noticed no improvement. After some other research I tried cleaning the maf sensor. No improvement. Since a replacement denso was only $70 on Amazon I thought what the hell. Id.give this a shot before messing with the O2 sensor. And sure enough it fixed the issue. My maf sensor was sending bad readings. Idle is now perfect again, 0% LT fuel trim, and mpgs back to normal. Just thought I'd post this as a FYI, bad maf seemed to drastically effect the fits mpg.
Old Feb 28, 2023 | 03:12 PM
3rdGenOwner's Avatar
Thanks for the heads up!
Old Mar 1, 2023 | 04:31 PM
Shadow Smith's Avatar
I've noticed my MPG dropping (98K miles) on my 2016 a tiny bit. I didn't think to use my scan tool. Thank you for posting. I'm going to check it out later.
I'm usually around 38+ consistently and noticed I'm down to 35 with my idle being a little off at times but no CEL. I was thinking spark plugs (since it's almost time to change them).
Steve
Old Mar 4, 2023 | 09:57 AM
Mister Coffee's Avatar
@Tslipknotm6 Thanks for sharing that information. Thinking about others once in a while is what makes this community.
Jazzl13a
23
Oct 13, 2022 06:24 PM
Jerry Mt
Jul 11, 2020 05:45 PM
pkunk
Mar 11, 2019 03:32 AM
im the fit
Oct 13, 2009 08:49 AM
leonine
Nov 9, 2006 11:23 AM
