overheat
Old Nov 8, 2024 | 07:50 AM
nofbob's Avatar
overheat
engine started overheating. replacing a thermostat didnt help, engine will drive on road fine, then after 1/2 hour temp will climb. i always immediately shut it down when the temp climbs, then let it cool and it is fine. i cant duplicate it in the shop. coolant has been purged of air, one time it overheated it blew 600cc of coolant into the bottle. am i looking at a head gasket?
bob
Old Nov 8, 2024 | 12:32 PM
Frenzal's Avatar
Normally, with the car cold, you can run it without the radiator cap. If there are bubbles, then your head gasket is failing.
Never open the radiator cap when the car is hot as hot coolant will splash everywhere and might burn you.
Old Nov 8, 2024 | 04:09 PM
56chevydan's Avatar
Are your cooling fans working? The main fan is temperature controlled and should come on when the engine heats up after starting the car and the coolant temp reaches 190- 200 degrees F. The A/C fan should come on immediately when you turn the A/C on. The fan circuits are protected with fuses in the fuse panel under the dash. The A/C fuse is #10 and is 15 amp. The main fan is in the same location and is #30 with a 30 amp fuse.
m1lkb0x
Jul 21, 2022 10:39 AM
spookyneo
Mar 14, 2022 06:40 PM
Bugzs15
Oct 28, 2013 02:37 AM
ohw
Sep 4, 2013 09:24 PM
theo.chan@gmail.com
Oct 19, 2005 02:39 PM
