HONDA FIT 2013 - Transmission Problem
Old Dec 31, 2024 | 11:16 PM
Cesarin360's Avatar
Hello, I have had this problem for over a year, where my Fit D flashes. When scanning it, it gives me the following fault codes:
I hope you can help me, I would really appreciate it.
Old Jan 1, 2025 | 09:01 AM
GrE8_Fit's Avatar
This guy has the same code. Did you unplug anything recently?
https://www.fitfreak.net/forums/3rd-...ml#post1375331
Old Jan 1, 2025 | 09:06 AM
Cesarin360's Avatar
Hi, thanks for your reply. I haven't disconnected anything.
Old Jan 1, 2025 | 11:34 AM
GrE8_Fit's Avatar
Maybe read through these and see if anything helps.
https://www.google.com/search?q=%22d...=firefox-b-1-m
Old Jan 2, 2025 | 01:21 AM
dwtaylorpdx's Avatar
Do you have the Automatic or the CVT? The autos had a external solenoid pack on the top of the trans kinda below the battery, easy to change and the solenoids are kind of a known occasional issue.. Easy DIY just remove and replace no adjusting or calibration required. one of those couple hundred dollar jobs the dealer wants 1500+ for.. I dont know if the CVT had them but the regular 5Speed did on the GD1 and it looks like my daughters current one with the 4 speed auto has a similar setup.
Old Jan 2, 2025 | 07:58 AM
Cesarin360's Avatar
Hi, thanks for your reply. No, it is not a CVT. I was told that everything in my transmission is fine, just that there is no communication with the TCM, but I can't find that module.
Old Jan 2, 2025 | 08:02 AM
Cesarin360's Avatar
Something I forgot to add is that the BREAK and ABS lights are on.
AnnieJ
Nov 17, 2023 05:11 PM
AnnieJ
Nov 17, 2023 08:36 AM
billinsf
Aug 4, 2023 10:48 PM
vec
Mar 24, 2014 08:35 AM
TKE
Car Shows, Events, and Racing
Mar 27, 2013 06:38 PM
