2014 Honda Fit Stalling when Cold
Old Apr 14, 2025 | 11:02 AM
HondaFit4evr's Avatar
Question 2014 Honda Fit Stalling when Cold
Hi Everyone, first time posting here and happy to contribute!
I have a 2014 Honda Fit (190 000km, automatic) that has a stalling issue when the engine is cold.
The car starts fine in the cold, with the cold engine icon being displayed on the dash. If I put the car into gear while the engine is still cold, the engine lowers rpm quickly down to ~500rpm and rumbles/putts for a few seconds before completely shutting off. I have the restart the car and let it warm up before moving. Sometimes I can put it back into park before it stalls, where then it rumbles at ~500rpm for a few seconds before idling back at a higher rpm. Once the engine is warm (and the cold engine icon is gone), the car acts normal.
I have replaced the battery, alternator, spark plugs, and just recently the engine thermostat with the problem still occurring (no codes showing as well). It is a little annoying to wait for the car to warm up every drive, especially with the long and cold winters in Canada.
I am at a little bit of a loss as to where to go from here. Does anyone have any ideas? Thanks.
Old Apr 14, 2025 | 12:46 PM
Frenzal's Avatar
Have you checked the grounds? They should be clean, without corrosion. If needed, replace them.
Are the battery connections good, tight and without corrosion?
Old Apr 14, 2025 | 12:56 PM
Thanks for the reply. Yes the grounds are clean, along with the battery connections. Battery was replaced a few months ago when I first started seeing the issue, so I hopefully eliminated that being the issue.
Old Apr 15, 2025 | 12:18 PM
mnpurplefit's Avatar
I had the same issue and a valve adjustment did it for me!
Old Apr 15, 2025 | 12:30 PM
Thanks for the reply. I have seen a few suggestions of that in other forums, so I think that is the next thing I will try!
donlogan
Sep 25, 2020 08:29 PM
hteejus
Dec 8, 2012 10:03 PM
forress
Jan 28, 2011 07:18 PM
aarfor
Oct 13, 2009 07:41 AM
hqly
Nov 19, 2008 09:09 AM
