headlights question
Old Aug 29, 2008 | 03:19 PM
cab0053's Avatar
headlights question
I read that the ge3 headlights can/need to be adjusted to brighten up. There is a DIY somewhere for it. Does the ge8 need it as well?
Old Sep 15, 2008 | 01:21 AM
badself's Avatar
Is it a problem or an operating characteristic?
The headlights on my '09 may need to be adjusted upward for better lighting. Should not be too difficult. It was simple on my '08 Mazda CX-9 with HID's.
On another note, can some '09 owners check their Fits for this characteristic: Each time my A/C compressor kicks on at night with the headlights on, the lights dim slightly due to a presumed voltage drop, and my HVAC fan slows a slight bit under the same conditions.
At first, I thought it may be related to idle speed, but I don't think so, as the brief dimming of the headlights occurs at higher speeds also. It's fairly noticeably while I drive, especially with how low the headlights are aimed from the factory.
Am I looking at a voltage regulation issue, or is the dimming simply due to the horsepower drain of the A/C compressor on the small displacement engine, or can it be due to the small size of the battery (which shouldn't matter if the electrical system is charging properly).
My car idles rock sold at about 800 rpm with the lights on or off, and with the A/C on or off, it maintains a stable and smooth idle speed even when the A/C and rear defogger are used simultaneously. The issue is not resulting from low or erratic idle speed.
The A/C compressor turns quietly and operates well, it doesn't appear to be drawing excessive amps. That's basically all my observations on the issue.
I hate to have the dealer mess with it when it may not be a repair issue. So, thanks in advance for checking to see if your Fit behaves this way.
Old Sep 15, 2008 | 02:28 AM
OneThinkingGuy's Avatar
Mine's exactly the same. The new Accord does the same too. It's on their forum as well. I wouldn't worry about it. Peter
Old Sep 15, 2008 | 03:51 AM
badself's Avatar
Thanks. I've been out there the last two hours messing with the nav and monitoring the voltage in the Fit thru my Bel Pro RX65 radar detector. It takes a full five seconds for the system to go from 14.0 volts with a/c off down to 12.8 when the clutch activates the compressor and back up to steady 14.0.
No damn wonder the lights dim. My Pilot never did this.
Nevertheless, I will defend my Fit, for it is now a member of the family, imperfect like the rest of us, but no less valuable.
Old Sep 15, 2008 | 10:07 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
i'm guessing it's from the initial ingaugement of the clutch.
after it ingauges it take a few second to get back up to
speed. small engine.
most likely perfectly normal.
Old Sep 15, 2008 | 10:51 AM
fitfanIU's Avatar
Has anyone yet adjusted the lowbeam headlights in the '09? They are aimed too low, and I guess I could put a few bags of sand in the back to point the nose up, but it will decrease my MPG.
Old Sep 15, 2008 | 12:10 PM
pinballlooking's Avatar
I adjusted mine big improvement!
https://www.fitfreak.net/forums/fit-...adlight+adjust
503ge8
Sep 14, 2022 01:33 PM
StuBeck
Jan 7, 2013 09:59 PM
fujisawa
Sep 26, 2012 11:37 PM
ej96hatch
Nov 1, 2009 07:44 AM
doogiefish
Jan 24, 2007 11:58 PM
