View Poll Results: Which horn did you install, or want to install?
Accord
74
61.16%
Bosch
4.13%
Fiamm El Grande
9.92%
Other (please state)
30
24.79%
Voters: 121. You may not vote on this poll
Old Nov 26, 2008 | 12:14 PM
trancedsailor's Avatar
I honked my stock horn at a jerkoff that pulled out in front of me when I was doing 50mph in a 45. I laid on the *** horn for like 20 seconds lol. If you pull out in front of someone and they have to brake pretty damn heavily to avoid hitting you, you're in the ****ing wrong. I hate those idiots.
Old Nov 26, 2008 | 01:42 PM
manxman's Avatar
I ordered a Wolo Bad Boy on sale at Northern Tool. Would prefer a deep truck-type horn, but in an emergency, a shriek is just as good as a bass tone- maybe even better. The "twice as loud as your stock horn" is what sold me.
Old Nov 26, 2008 | 01:52 PM
animes2k's Avatar
Our Hella Supertones have DEFINITELY gotten peoples attention. One lady went so far as to cover her ears
Old Nov 26, 2008 | 05:35 PM
any soundclips? I want a new horn after laying on it this morning. The dude probably laughed at me.
Old Nov 26, 2008 | 05:59 PM
manxman's Avatar
Most horn manufacturers have sound clips on their web sites. You just have to look them up.
Old Nov 26, 2008 | 06:07 PM
okay thanks, I'm just feeling so lazy today ;/ sorry
Old Nov 26, 2008 | 06:32 PM
petwhookie's Avatar
I use Hella Horns, nice and loud. Shakes the frame of my car haha
Old Nov 26, 2008 | 06:42 PM
theloxmyth's Avatar
Fit Gadget Freak
Don't ride the horn pad too long. The 15A fuse will blow.
(Don't ask me how I know ; )
Upped the fuse to a 20A, but I will not ride it long again, just the same.
Old Nov 26, 2008 | 07:41 PM
animes2k's Avatar
Check YouTube for supertone clips. There are plenty comparison clips
Old Nov 26, 2008 | 07:47 PM
StewPiddass's Avatar
Why hasn't anyone just put the previous gen Fit horn on? That was the common mod on the 8th gen Civic forum to make it sound less "wimpy"
Old Nov 26, 2008 | 09:22 PM
AZEqualizer's Avatar
I put in the horn from College Hills Honda
Low note horn - 2.4 liter - 2.4 liter 2007 Honda Accord coupe $18.52
It is a Bosh Low note horn and it fits like a glove with no modification required.
Old Nov 26, 2008 | 09:29 PM
  #32
manxman's Avatar
Thanks for the heads up Craig. I intend to use a relay for the Wolo to draw direct battery power to it, increase the horn fuse amperage, and keep the stock horn in place. A short bump on the steering wheel horn switch will produce the wimpy "Meep" that we all don't like, but a lean on it will bring both horns into play.
Old Nov 27, 2008 | 10:58 AM
  #33
theloxmyth's Avatar
Fit Gadget Freak
Good move!
That's my second move, installing the relay system.
Old Nov 27, 2008 | 12:23 PM
  #34
JDM_DOHC_SiR's Avatar
Lightbulb
Originally Posted by indypain
Can you tell me which horn you replaced? The Honda parts guy here tells me there's 2 horns in the Fit too...high and low note? thanks
One of those horns is for the Alarm...
Old Nov 27, 2008 | 12:51 PM
  #35
OK when you say the '08 Accord horn is 'plug n' play' what do you mean? You can just literally unplug the FIT horn and plug in the Accord horn and it works fine? Isn't the Accord horn bigger? And aren't there actually two horns? I'm not very mechanically inclined so would appreciate any detailed instructions on this 'cause I HATE the Fit horn and would like to replace ASAP! Thanks
It is literally plug and play. Yes the horn is bigger (buy only the low note horn) but the one I got looks like it was made to fit there... and there is enough room not to conflict with anything. You have to remove the bracket with the std horn. The replacement has it's own bracket and mounts to the same spot and snuggles right up to the hood latch cover without distorting it. . The connectors are identical and the power ratting is close enough no fuse change is needed.
BTW this low note horn replaces the stock horn (by the hood latch) not the alarm horn.
Old Dec 6, 2009 | 07:04 PM
  #36
Selden's Avatar
The compressor motor on an air horn typically requires a lot of juice. The horn circuit fuse on a GE Fit is only 10 Amps, and not knowing the size of the wires, I decided to run a 14 gauge wire (with a 20 Amp fuse) from the positive terminal of the battery to a relay, then a short 14 gauge to the horn, and use a 14 gauge ground wire. It's very reliable and very loud. The relay requires a separate ground wire.
Old Dec 31, 2009 | 01:34 PM
  #37
jonboy108's Avatar
piaa sports horn
Just bought a pair of "high" tone PIAA sports horns- from Amazon, of all places, they have the Hella supertones and the FIAMM freeway blasters too. Sooo, my New Year's Eve craft activity will be boltin' these babies onto my '10 Fit.
Old Dec 31, 2009 | 01:45 PM
  #38
vinn's Avatar
i have the accord horn
Old Dec 31, 2009 | 03:36 PM
  #39
whaap's Avatar
I still have the stock horn. I haven't upgraded it because I don't use a horn. If I find myself in a precarious situation I will use what few fractions of a second I have taking evasive action and not leaning on the horn. I learned a long time ago I wasn't going to teach the world how to drive.
Old Dec 31, 2009 | 03:50 PM
  #40
Barb's Avatar
I'll likely go with the Stebel Nautilus. We use them on our bikes too. Great for getting peoples attention. But as Seldon said, will have to run a separate circuit as a 10 amp fuse won't cut it.
Barb
