Grindy sticky key
Old Dec 2, 2008 | 09:27 PM
tietack's Avatar
Grindy sticky key
Folks,
My wife's key sounds a little grindy when being inserted in the ignition (or the door). My key isn't so "grindy".
I don't know if that's an indicator of a bigger problem.
My instinct is to just add a bit of key lubricant - or maybe even WD-40, but I don't know if that would screw up the anti-theft characteristics of the key or lock or something else.
Would appreciate your help.
Old Dec 2, 2008 | 10:12 PM
theloxmyth's Avatar
Fit Gadget Freak
Exclamation Use WD-40
Originally Posted by tietack
Folks,
WHAT YEAR IS IT?
I wouldn't hesitate to spritz a small amount of Water Displacement, 40th formula (WD-40 : ) into the keyway.
You might also consider something with silicone in it, instead of WD-40, but I would use WD-40!
WD-40 Frequently Asked Questions
Use the red straw.
+1 REP for the new guy!
Old Dec 2, 2008 | 10:50 PM
AZEqualizer's Avatar
Don't want to use WD40 in locks you are better off to use powdered graphite.
Old Dec 2, 2008 | 10:55 PM
Virtual's Avatar
Exactly what I was going to say. For locks: WD40=bad. Graphite=good
Old Dec 2, 2008 | 11:03 PM
theloxmyth's Avatar
Fit Gadget Freak
Exclamation Ouch!
Yes, you can use graphite in old style pin tumber, or wafer type cyliders, if you choose to.
(I will continue to use WD-40, as I have for the past 20 years in this business.)
Graphite is abrasive to new style car locks.
Especially laser-key type wafers!
Graphite is a form of carbon, as is a diamond.
Thousands of locksmiths ought not to be incorrect in this assessment.
Craig, The Loxmyth
Registered Locksmith
Certified Journeyman Safecracker
Old Dec 2, 2008 | 11:09 PM
theloxmyth's Avatar
Fit Gadget Freak
¿WHY do you say that?
Old Dec 2, 2008 | 11:21 PM
tietack's Avatar
The car is an '09 Fit Auto Sport - so it uses the key with the "electronic circuit". So I'm concerned that the wrong lubricant would screw up whatever circuits might be embedded within the key.
Old Dec 2, 2008 | 11:26 PM
SCBarren's Avatar
Mmmmm... Play it safe and take it to the dealership?
Old Dec 2, 2008 | 11:27 PM
theloxmyth's Avatar
Fit Gadget Freak
Thumbs up OK. Valid concern!
You will not be spraying it on the key.
Besides, the transponder is embedded into the molded plastic head of the key.
I've read that it will survive a wash cycle in your washing machine!
The transponder circuitry, located on the exterior of your ignition cylinder, is isolated from the keyway.
HTH!
Old Dec 2, 2008 | 11:40 PM
theloxmyth's Avatar
Fit Gadget Freak
Exclamation Vivid illustration
VIVID ILLUSTRATION, just for you.
Old Dec 2, 2008 | 11:42 PM
theloxmyth's Avatar
Fit Gadget Freak
Thumbs up YES. Dealership warranty work!
I agree!
...2009!!!
DEALERSHIP, FOR FREE!
Fr8Dog
Jan 14, 2019 11:48 AM
Honzo
Mar 21, 2017 10:33 PM
hookerfit
16
Aug 19, 2016 02:46 PM
Dave Edelhart
Jul 19, 2014 08:31 PM
Eta-Carinae
Jun 16, 2009 11:09 AM
