anyone else hear this noise?
Old Dec 9, 2008 | 03:21 PM
spin out's Avatar
in my auto fit sport, upon first start of the day only, i put the car in reverse, back out of my parking space, stop and then put the car in drive. at the moment of putting the car into drive, there's a semi-significant thud-like sound that comes from under the rear, center the car.
anyone else hear this?
any reason to be even remotely concerned?
it only happens on first trip of the day.
Old Dec 9, 2008 | 03:24 PM
JDMxGE8's Avatar
I hear it too sometimes. I think it's just the tranny.
Old Dec 9, 2008 | 03:56 PM
theloxmyth's Avatar
Fit Gadget Freak
Question
¿Does it sound as if the noise is coming from inside the door panels, like what I am hearing on my USDM Base 08 (GD3)?
It occurs when I shift my A/T into drive.
¿Disabled auto door lock feature?
Do the Sport models "auto lock"?
Old Dec 9, 2008 | 04:05 PM
spin out's Avatar
it's definitely not coming from the doors.
it's underneath the car, behind the driver, near the center.
Old Dec 9, 2008 | 04:12 PM
theloxmyth's Avatar
Fit Gadget Freak
Thumbs up
Just wanted to let you know that I do pay attention to the words, my friend.
What I hear seems to come from the area of the door panels.
Old Dec 9, 2008 | 04:23 PM
reako's Avatar
Yes, I have the exact same sound, I believe it's normal.
Old Dec 9, 2008 | 05:28 PM
JDM_DOHC_SiR's Avatar
Exclamation
If you guys see how much the 09 Fit Engine moves you would sH!T your pants.. it might be engine mount related or exhaust ... or Gas in the Tank..??? But anyways I`m going to see if there is anyone that is going to make a damper/ stiffer mounts for this car.. becuase the GE8 Needs it for sure...
Old Dec 9, 2008 | 06:02 PM
reako's Avatar
It's really just sounds like the tranny is "clicking" into gear.
Old Dec 9, 2008 | 06:08 PM
Fitcapo's Avatar
Sounds like you might still have your car rolling when you switch gears. My car does it occasionally if I am rolling backwards and switch into drive or s.
Old Dec 9, 2008 | 06:22 PM
reako's Avatar
Nope, I'm quite careful not to do this!!...........it's my brand new car!!! It clicks right when the car begins to roll forward.
Old Dec 9, 2008 | 06:56 PM
Tork's Avatar
First start, cold engine, your RPM could be up.
That could cause a thud when changing gears R to D
Now couple that with what JDM_Sohc_Sir said about engine movement and you got something normal and nothing to worry about
Plus you might have the option of backing into your space!?!?
Your location is USA, cold climate or warm?
Old Dec 9, 2008 | 07:47 PM
Lek's Avatar
Lek
Yep, on autos, it's the tranny clicking into gear R-D & D-R only. The new civic is the same.
I know it's hard to do, but try to forget about it unless it gets very loud then take it to the dealer.
Old Dec 9, 2008 | 10:23 PM
Julio's Avatar
I get a sound but it's more like a grinding sound from the engine. It happens about 5-10 seconds after every time I start the car, either when I'm in Reverse or Drive...
Old Dec 9, 2008 | 11:04 PM
spin out's Avatar
the consensus here seems to think it's the transmission clicking in.
thanks all for your input.
Old Apr 1, 2009 | 09:40 AM
Hipshot's Avatar
ok.. I got something similar but more dramatic. From park on a downhill slope only. Parked on an uphill slope doesnt do it. Anyway, put it in gear.. roll 5 feet in gear loud clunk noise from the tranny. Coast no noise till I put it in gear...then 5 feet.. knunk! I mean loud! You can feel it in the shifter!
My guess... the parking pin gets stuck parked on a down hill slope and gets knocked back into place once in gear. Doesn't seem normal to me. But it has done it since new. 8k on it now.
I plan to question it whne I get back to the dealership. In the mean time.. any ideas?
Old Apr 1, 2009 | 10:23 AM
Committobefit08's Avatar
Spin Out
Its normal. Mine does it every day.
My CL-S used to do it too...its the tranny going into gear.
hogwylde
Sep 19, 2014 09:41 PM
ltd
Apr 30, 2012 06:51 PM
ltd
Apr 23, 2012 06:41 PM
runbikerun
Jan 23, 2009 04:56 AM
girkabob
Jun 15, 2008 10:36 PM
