Satellite Radio using the USB in Glovebox?
Old Dec 17, 2008 | 10:11 AM
dennyd's Avatar
anyone able to get a portable satellite radio to work with the USB connection in the 'upper' glovebox??
Old Dec 17, 2008 | 11:53 AM
Satchel's Avatar
How would that work exactly? AFAIK the USB port is only for thumb drives or iPods/iPhones.
Why not use the existing aux-in jack on all the models? I did for my XM Inno.
My Inno has a USB jack for syncing with a computer for software updates and moving music to the memory, but I don't think audio flows through that port.
neteng101's Avatar
Uhhh - I don't know of any satellite radios with USB type connections?
They normally have an aux out, which goes into the aux in port just fine.
Old Dec 17, 2008 | 12:24 PM
skyghene's Avatar
Something like a Sirius Stiletto would have a USB connection... but no it wont work with the USB on the Fit. You will have to use a 3.5mm male/male audio cable to the aux. If it charges through USB you might be able to use the USB connection to charge it while you listen.
Old Dec 17, 2008 | 12:41 PM
dennyd's Avatar
thanks everyone! think i got the idea-- now just need to find the 'aux in' on the radio.. (i have Navi-- the radio is part of the navi system)
Old Dec 17, 2008 | 12:59 PM
Satchel's Avatar
The aux is down low on the center stack next to the 12 v power jack in front of your shifter.
Joshua S Gabrielson
Apr 11, 2014 09:33 PM
johnoshea
Aug 3, 2012 06:59 AM
thewwkayaker
Oct 31, 2011 12:35 PM
cruzn246
May 11, 2011 07:43 PM
crosshockey12
Sep 7, 2008 02:20 AM
