Cargo light upgrade
Old May 18, 2010 | 01:51 PM
  #81
olsoncor's Avatar
will the one stop customs LED insert work for this light the same as the stock Honda Fit? Switch is a good Idea but if i had to chose between a crappy light with a switch and an LED that works well, Id go LED. Anyone tried this?
Old May 18, 2010 | 02:03 PM
  #82
gd3vbp's Avatar
Why don't you do both?
Old Jul 18, 2010 | 06:33 PM
  #83
Blue's Avatar
Just checked with my local Honda Dealership and this item is only available ex-Japan and will take 2-3 weeks for delivery with a NZ$35 price tag. Due to this, I'll be doing a very simple 1.5W festoon LED replacement and will share before/after pics when I'm done.
Old Sep 16, 2010 | 02:55 PM
  #84
johnkyr's Avatar
Originally Posted by niko3257
now take the old cargo light and cut all the stuff off the back.
make sure you leave out the parts that is utilizes as the holders.
sorry i don't have any good pics of this. this is the best one i have.
cut it all down to about 1/2 inch
now i cut 2 slots and slid the led under. then as for the other side
i screwed it down. use a very small screw and make sure you pre-drill.
should look like this.
now it's all done. finished product should look like this.
now just so you know the plug you keep seeing at the end of the led is
not going to be used. I cut it and spliced a wire about 3 to 4 feet long
to it.
now run the wire to your cargo light.
[skipped most of the pix in the quote]
niko you did a really great job there, i was looking for a solution on the light issue and i found it here! i will try to do it but first i have a question. where did you find the clear plastic cover for the light?
Old Sep 16, 2010 | 03:05 PM
  #85
Punisher11's Avatar
https://www.fitfreak.net/forums/2nd-...tml#post541559
first post dude lol
Old Sep 16, 2010 | 03:29 PM
  #86
Lil Blue's Avatar
Ordered my switched light today, will decide after if I want to do the upper one later since I want to get the cargo cover.
Old Sep 16, 2010 | 03:32 PM
  #87
johnkyr's Avatar
Originally Posted by Punisher11
ok that was funny :P
i can't locate that item on ebay, could anyone suggest an online shop?
Old Sep 16, 2010 | 05:24 PM
  #88
Lil Blue's Avatar
hondapartsunlimited.com they can also order acura parts
Old Sep 16, 2010 | 05:46 PM
  #89
johnkyr's Avatar
thank you very much for the quick response!
there is a slight problem though; this shop won't ship outside the US.
Old Sep 16, 2010 | 06:05 PM
  #90
Lil Blue's Avatar
Oh, you just asked for online, lol, sorry, they are a honda dealership, did you ask them?
Old Sep 16, 2010 | 06:28 PM
  #91
johnkyr's Avatar
i'm gonna ask them tomorrow and i am pretty sure that the answer for a part that they don't have in stock will be like €40-50 or something which is not worth it..
Old Sep 21, 2010 | 04:43 PM
  #92
Scala's Avatar
can you use that same cargo light switch for the GD? thanks
Old Sep 22, 2010 | 07:17 AM
  #93
Lyon[Nightroad]'s Avatar
Niko I never let you know this but I admire the DIY spirit. Without it, we would all just be a bunch of hellaflush bolt on clones.
Old Sep 25, 2010 | 10:28 AM
  #94
niko3257's Avatar
FitFreak GE8 DIY Guy
If the part #'s are the same. Yes you can.
Old Sep 25, 2010 | 10:31 AM
  #95
niko3257's Avatar
Thanks man. Much appreciated.
I also like what you do also. The light mod in the a/c
vents is really nice. +rep to you sir
Also look out. I will be doing another DIY soon. In detail
like usual.
Old Sep 25, 2010 | 12:46 PM
  #96
Farther's Avatar
Just ordered one. I take a wood shop class after work and haul materials in the Fit. While the class starts before sundown, it ends after sundown and I noticed my cargo light was on for the full three hour class. This will help.
Old Sep 27, 2010 | 02:20 PM
  #97
johnkyr's Avatar
i have a problem with the cargo light but i asked Honda dealers for the centre armrest, and it will cost €380 + installation. so i suppose that cargo light might be like 50 or something. hell no!
the problem with the cargo light is that there is no light in the first place, so i think that there is no electricity to fix this DYI. you can check the photos if you like and tell me your opinion.
Old Sep 27, 2010 | 03:42 PM
  #98
gd3vbp's Avatar
You're looking in the wrong place for electrical, but either way it wouldn't be hard to wire in. You'd need a constant 12v source from the fuse panel and you can ground it about anywhere...
Old Sep 27, 2010 | 04:25 PM
  #99
B-Blue's Avatar
Well I wanted to get some LED's from OneStopCustoms but seems like he fell of the face of the earth.
Old Dec 28, 2013 | 11:05 AM
  #100
2poler's Avatar
just found this and now need to order more parts
SleepyNyte
Jan 29, 2011 11:02 PM
motorman
Aug 13, 2010 07:50 PM
jenhonski
Mar 29, 2009 05:15 PM
HONDAMATIC
Hawaii Community
20
Jul 28, 2008 01:02 AM
piyoimut
Jun 26, 2007 08:32 PM
