Throttle Surge on Upshift
Old Jan 16, 2009 | 02:07 PM
Steven Hung's Avatar
After driving my 5 speed 2009 Fit Sport for six days I noticed an annoying problem during up shift from a lower gear to the next higher gear. When I lift my foot off the gas throttle then depressed the clutch pedal before up shifting, there is a throttle surge. I could see the tachometer RPM climb up several hundred RPM. It seems as if the throttle body butterfly is stuck momentarily before full closed. There is no RPM surge when I downshift from a higher gear to the next lower gear after braking to slow down the car. I have examined both the throttle body and throttle body cable and they are working properly. The only thing I could attribute this problem to is the Honda drive-by-wire. Has anyone with a 5 speed FIT notice this problem? I have another vehicle that is not made by Honda that has a drive-by-wire system and it doesn’t have the RPM surge problem.
Old Jan 16, 2009 | 02:33 PM
SCBarren's Avatar
I kinda know what your talking about. Before its completely engaged in gear, it almost seems like more power is being produced, then once I let off the clutch pedal it doesn't happen.
I don't think its only you.
Old Jan 16, 2009 | 02:54 PM
Alpha Zero's Avatar
haven't really noticed, but haven't really paid attention either. I'll check it out on the drive home tonight.
Old Jan 16, 2009 | 02:58 PM
BakedCookies's Avatar
bingo!!!!!!
Old Jan 16, 2009 | 03:20 PM
mole177's Avatar
the only time that happens to me is when i havent fully lifted off the gas pedal when the clutch pedal is depressed.
Old Jan 16, 2009 | 03:23 PM
Im|Inside|Fit's Avatar
Originally Posted by BakedCookies
bingo!!!!!!
yep its jsut the drive by wire =/ thats what sucks about it... it has a little lag to it before it climbs up again...
Old Jan 16, 2009 | 04:48 PM
Olyar15's Avatar
It's not "just" the drive-by-wire. It is because of emmisions. When you lift off the throttle to upshift, the sudden throttle closing causes the car to run a bit rich for a fraction of a second. While it may not seem like much, cars these days are extremely low-emissions, and the standards are getting tougher all the time. That is one disadvantage about manual transmissions. Previous Hondas, even without drive-by-wire, had similar problems where the revs would "hang" and not drop immediately after lifting off the throttle when upshifting.
One way to get around this is to lift off the throttle before pushing in the clutch pedal. It takes a while to get used to, especially if you have other manual-transmission cars that don't do this.
Old Jan 16, 2009 | 04:50 PM
yep, as posted above, it's for emissions to burn all (most) the fuel before it leaves
your car.
once you get use to it it wont bother you. you'll just naturally learn to roll off
the throttle smoother.
Old Jan 16, 2009 | 08:57 PM
Masafina's Avatar
yeap
I notice that to but I know is the drive-by-wire
Old Jan 16, 2009 | 10:23 PM
method:fitsport-K's Avatar
There is your answer.
Old Jan 17, 2009 | 12:36 AM
Alpha Zero's Avatar
hmm... on the drive home, i paid special attention and i didn't notice any reving during upshifts.
then again, i drive like a granny.
Old Jan 17, 2009 | 12:59 AM
hanzo's Avatar
The clutch catch point is very high so if you left off the clutch faster you'll avoid that surge.
Old Jan 17, 2009 | 02:28 AM
Goodguy-Fly's Avatar
This. It works perfectly. It took a while for me to get used to.
Old Jan 17, 2009 | 03:06 AM
vinn's Avatar
mm thanks. been wondering what this sound was
Old Jan 17, 2009 | 04:01 AM
It is going to take time to get use to lifting off the throttle and wait a couple of seconds before depressing the clutch. That is going to painful when you are stuck in stop and go traffic. Well I guess that is the price to pay for a greener car.
Old Jan 17, 2009 | 04:21 AM
Olyar15's Avatar
You don't have to wait a couple of seconds. Just lift off the throttle a moment before you start pushing in the clutch. Just try it out and see how long a delay you need in order to get smooth shifts. It's not that bad after a while. And it's not as bad as my previous Honda: 2002 CR-V.
Old Jan 18, 2009 | 11:20 AM
pharmpk's Avatar
I read about this 'problem' before I went with my wife to pick-up her new MT Fit. She traded in a MT Mazda 3. As a passenger I notice the high rev during changes. I think part of it was a different car. As mentioned the clutch points are different. The Mazda had a heavier clutch. I'm sure she will get used to it. Many of the shifts on the way home didn't seem to have as much of a surge if any so it should be just an adjustment of style.
Old Jan 18, 2009 | 07:03 PM
for those of you that think 'drive by wire' is the problem it really is not because
my other cars (MT) are both drive by wire and do not do this.
it has to do with the ECU map on the Fit's. honda programmed it to burn off
the fuel all the way before the engine spins down to improve emissions.
Old Jan 20, 2009 | 12:02 PM
I<3_myfit's Avatar
like everyone is saying really common with any car iwth a drive by wire. The Blitz makes a throttle controller (it does wonders on my g35 no surge and response is night and day). i hope they come out with it for the Fit.
Old Jan 20, 2009 | 12:12 PM
shonda1989's Avatar
7th gen accords do this also but only with a intake and an exhaust is it noticeable. also the blitz controller can be used on our cars it just needs to be wired correctly. someone is trying to wire it as i type on V6P.net.
