K20 Fit - Garage FK
Old Feb 18, 2009 | 09:51 PM
Tetsugen's Avatar
K20 Fit - Garage FK
Glad to see it finally done.
From BM Hot Version Vol.95
The GE had a
k20 swap 230ps and weighed in at 1050kg
Teins
Brembo brakes
215/45/17 in the front and 195/55/15 in the rear
1'06"163 at tsukuba
vs. the J's GD 1'02"256 (330ps and weighed 880kg)
The GE come last even though had 5 sec head start on the tsukuba track.
Odd wheel size though.
Auto Otaku: Car and Life: Garage FK GE8 Honda Fit
garageFK website!!
Old Feb 18, 2009 | 10:00 PM
Fat Ping Cat's Avatar
i want to see some stats
Old Feb 18, 2009 | 10:26 PM
dewthedew's Avatar
wtf 17s up front 15s in the back
Old Feb 18, 2009 | 11:20 PM
tobey457's Avatar
Someone PLEASE make a plug-n-play K20 swap kit!!!
Hey I can dream can't I?
Old Feb 19, 2009 | 10:53 AM
BakedCookies's Avatar
Now that's hot, wish there was more detailed info about the swap process. Not that I will ever do it, just would like the knowledge.
Old Feb 19, 2009 | 12:29 PM
mole177's Avatar
as cool as it seems, i bet it does not have a/c... no deal for me.
Old Feb 19, 2009 | 12:32 PM
JDMxGE8's Avatar
Nice. I'll probably get a K24A2 after I rape the L15A7. Weird tire/wheel sizes though...
Old Feb 19, 2009 | 12:42 PM
mole177's Avatar
a lot of FR high power cars have the bigger wheel in the rear....
the rear should be 16...
but the front is 17 b/c of a brake upgrade.
Old Feb 19, 2009 | 12:45 PM
JDMxGE8's Avatar
Not a lot, but some do. Normally, FR cars run a staggered setup, but the same size diameter wheels.
Old Feb 19, 2009 | 12:52 PM
solbrothers's Avatar
are you serious? tons of cars have smaller diameter wheels in the front.
Old Feb 19, 2009 | 01:05 PM
iKONA636's Avatar
Im not great with performance and setups for performance but couldn't it be because its a front wheel drive? Also because of hte big brake kit? And the rear wheels are just there for the ride?
Allot of the cars we see with bigger rear wheels are RWD. Mustangs, Camaros, etc.
Im not sure. But It has to be for some reason. If hes building his fit for racing hes not going to put bigger wheels in the front just for fun and to be different. Its probably for a reason that would benefit him.
No_Skillz's Avatar
Need tech specs. Or a kit. NOWz.
Old Feb 19, 2009 | 01:15 PM
AnlDyxp_GD3's Avatar
damn thats gangster. And once again, base Fit ftw! =]
Old Feb 19, 2009 | 02:12 PM
dirtybird222's Avatar
engine bay pics or it didn't happen
Old Feb 19, 2009 | 03:16 PM
MNfit's Avatar
my only guess for the odd wheel size is the brake kit and to help save weight
Old Feb 19, 2009 | 03:58 PM
No_Skillz's Avatar
There is an engine bay shot and an installation shot on the garageFK website.
Old Feb 19, 2009 | 04:08 PM
JDM_DOHC_SiR's Avatar
Arrow
It`s actually not a base model .... That trim that is on that fit is the RS trim or GE-8 Chassis
Old Feb 19, 2009 | 04:11 PM
hanzo's Avatar
FWD with larger wider wheels up front does make sense. FWD understeers (front wheels break traction first) so larger contact patch up front more (higher tolerance for grip) to balance out the rear end.
Old Feb 19, 2009 | 04:59 PM
Bassplayer's Avatar
My hypothesis on the wheels is that he's running 17" up front to clear the big ass Brembos, and then running 15" in the back to use lighter wheel to save weight, rotational mass,etc (small size still clears stock rotors he's using).
Old Feb 20, 2009 | 04:11 AM
ghettoboy247's Avatar
total sex! Wana c da vid now but man, talk about being outmatched by the J's GD!
