Camber kit/bolts
Old Mar 12, 2009 | 03:46 AM
OEMfit's Avatar
Camber kit/bolts
I can't find any decent ones for the GE8! Are the GD3 camber bolts compatible?
Old Mar 12, 2009 | 06:56 AM
ghettoboy247's Avatar
what undecent kits did u find?
Old Mar 12, 2009 | 08:14 AM
BakedCookies's Avatar
you need to order part # 90188-SCC-A00 Qty 2
from norihito1@gmail.com
That's what I am using on my car.
Old Mar 12, 2009 | 02:35 PM
OEMfit's Avatar
Its mostly ebay ones and overpriced for just bolts!
Old Mar 12, 2009 | 02:36 PM
OEMfit's Avatar
Thanks for the part #, I just found it here. But I will try to see if my local dealer have it instock.
90188-SCC-A00 - Genuine Honda Bolt, Flange (14x57.3)
Old Mar 12, 2009 | 04:42 PM
I have two for sale, see my sig...
what is the above picture for? That is not where the camber bolt goes, that is the mount for the sway bar endlink.
Old Mar 12, 2009 | 05:22 PM
JDM_DOHC_SiR's Avatar
State side dealers have these bolts now..... I don't know the part# off hand but I called this mornig and they said that they can order them
Old Mar 12, 2009 | 05:46 PM
OEMfit's Avatar
Oops wrong image...
Damn if I knew you had them available I would've ordered it from you... Thanks anyway
Old Mar 12, 2009 | 06:03 PM
OEMfit's Avatar
Ya I just got back from my local part dept and they said it was special order only. It cost $6.74 each, but I ended up ordering through them so I can save on shipping.
I should've inquired about the USDM Mugen parts but I forgot....
Old Mar 13, 2009 | 02:38 AM
so what about this SPC camber kit i've been hearing about? Any1?
Old Mar 13, 2009 | 09:59 PM
1FiTpINOY's Avatar
I ordered the SPC camber kit for when I lower my car on the DF's. From what I found, the GE8 uses the same size bolt as the GD's. All are 14mm.
And also, a little bird whistled the hint to me.....cough Dave...cough
Old Mar 13, 2009 | 10:49 PM
jaydubz79's Avatar
Does any one think it will be necessary to worry about camber and such with a minimal drop such as 1.2 inches like the Eibach set up will be?
Old Mar 13, 2009 | 10:56 PM
1FiTpINOY's Avatar
Do this:
Drop the car (because I know for sure you want to/will), then go to a local shop and do an alignment. If they say your alignment needs special adjusting, then go ahead and order them
This way you know for sure if you need them or not
whitefitsport
Oct 2, 2018 10:54 PM
BakedCookies
Nov 7, 2012 04:27 PM
kyobi
Jan 30, 2012 08:50 PM
diedwater
Jun 26, 2009 09:45 PM
Spooling
Oct 9, 2008 02:23 PM
