Sound Deadening Step #1
Old Mar 15, 2009 | 01:34 AM
vwli's Avatar
I spent the whole day laying Dynamat on the trunk area. It took 5 sheets and I have some bruised knuckle and cut fingers. I only drove locally so far and I cannot really tell the difference. I will take it on the freeway tomorrow and try it out.
Step #2 will be doing the doors. Hopefully with 4 sheets left, I will have enough. I am planning to change the speakers at the same time.
Here are some pics:
Old Mar 15, 2009 | 02:30 AM
qbmurderer13's Avatar
Nice, I like dynamat. Although I dont think the Fit is loud enough to warrant the extra pounds added by the dynamat.
Old Mar 15, 2009 | 03:30 AM
dgs's Avatar
dgs
I have never heard of "Dynamat" until I read this thread. Then I googled it and learned it's sound deadening material for vehicles. Pretty cool I guess but it sounds like the OP went through a lot of time, expense, and pain to quiet a car that is already extremely quiet for an economy car. It's probably the quietest Honda I've evern ridden in. I'm been in some Civics and Accords that could have used this stuff much more than my 2009 Fit.
Each to their own. If you want your Fit to be as quiet as a Lexus I guess that stuff will do the trick, but the car is plenty quiet for me. I actually expected it to be noiser on the freeway so I've been pleasantly surprised.
Old Mar 15, 2009 | 10:27 AM
vwli's Avatar
I only used a little over 10 lbs of material for the project so far. So it is not that bad. If I do the door later, it will add another 10. So I don't think adding 20 lbs would hurt the performance and gas mileage on the Fit.
For some reason I found the Fit noisy. May be I got the manual sports. Especially on freeway. Depending on the road surface, it makes a lot of road noise (the low profile tires on Sports?). Also the engine rev a little higher on 5th than the automatic and it makes more noise.
Old Mar 15, 2009 | 01:06 PM
713_fit's Avatar
its noisy to me
but i dont care
dynamat is good..but there other product out there cheaper and better..i forgot what brand it was
this is really good espcially if you plan to get a sound system in the car!!!
Old Mar 15, 2009 | 02:09 PM
SportMTNavi's Avatar
Thanks for sharing the pictures. Can't wait to hear what you think of the results. I find the Sport M/T a little noisy on the highway, too. It's a lot quieter than our '90 Miata, though, and the engine turns the same RPM at highway speed.
Cheers.
Old Mar 15, 2009 | 05:21 PM
vwli's Avatar
Just took my Fit on the freeway for a spin. A lot more quiet than before. I used to set the volume to 6 on the radio, now I can listen at 4. I am very satisfy with the result. I think I am going to order the speakers and work on the doors soon.
Quiet Fit is a Happy Fit!!!!!!
Old Mar 15, 2009 | 09:06 PM
Tork's Avatar
I noticed the other day, driving with the rear seats down that it was noisier than with the rear seat up. So doing the back like that would be helpful.
And nice job you did!
Old Mar 16, 2009 | 12:19 AM
reako's Avatar
Looks great man, nice job! This may become a summertime project for me; these photos will be a nice reference. This would also help cut down on any excessive exhaust sounds (should you ever consider this, I know I will )
After reading countless comments about cuts and other injuries during these installs, I will definitely wear gloves! Thanks again, enjoy!
Old Mar 17, 2009 | 05:46 AM
jmpet626's Avatar
Nice deadening... Could you please post some pics on how to remove the panels? I had my front doors deadened in the shop and I plan to DIY my trunk area with Flashband
Old Mar 17, 2009 | 09:07 AM
vwli's Avatar
I did not snap any pic of how to remove the trim panels. But you can check out this thread:
https://www.fitfreak.net/forums/2nd-...heel-well.html
Basically just use the trim removing tool to pull the snap pin off. No screw there. This is the removal breakdown:
- spare tire
- tire jack
- cover panel for spare tire
- trim panel at bottom of hatch
- pull off a little of weather trim strip at rear doors which overlap quarter panel on both sides
- remove covers for rear struts and lights on quarter trim panel
- pull on rear quarter panels to loosen panel + use trim removal tools to pull snap pin off
- disconnect cargo light on driver side panel (pop light assembly off from panel before disconnecting, use screw driver cover with cloth to pry it off)
Good luck. BTW, after you done the sound deadening of the front doors, is there any significant improvement? Is it easy to take front door panel off?
Old Mar 20, 2009 | 02:23 AM
TWGE08's Avatar
Yea I'm contemplating whether or not to use some sound deading. Let us know how the doors go.
Old Mar 20, 2009 | 06:40 AM
Kyokutou23's Avatar
Excellent write-up,
I'll be doing the same thing soon, summertime project that'll go along with when I'm ready to to make my fiberglass enclosure in the spare tire area (slim sub set-up). I've used Dynamat before but switched over to a company called Cascade Audio Engineering (Automotive Noise Control - Soundproofing). I really like this stuff used it on my last three cars. You can get different thicknesses so you can adjust the damping level and watch the amount of weight you put into the vehicle. They also have a spray for those hard to reach areas (a little messy though) Oh yeah and it doesn't stink
Anyways thanks for the write-up and the pics, showed me what I have to look forward to this summer.
Old Mar 20, 2009 | 07:23 AM
jmpet626's Avatar
- spare tire
- tire jack
Yup mid bass did improve a lot. As for the road noise, not much of a difference.
Old Mar 21, 2009 | 06:00 PM
TWGE08's Avatar
Any idea on how many sq ft you need to do the hatch area and doors on the fit?
Old Mar 21, 2009 | 06:12 PM
vwli's Avatar
The area that I covered so far took 5 sheets of 18" x 32" of Dynamat Extreme.
I was making some measurements. 4 shts of 18" x 32" of dynamat extreme left over should be enough for 4 doors on the outer skin. I just ordered 2 packs of CAE DK-1 to cover 4 doors on the inner skin.
Old Mar 21, 2009 | 08:05 PM
How much weight do you think was added when doing just the hatch area?
Old Mar 21, 2009 | 08:34 PM
vwli's Avatar
a little over 10 lbs.
Old Mar 24, 2009 | 01:52 PM
jbyron's Avatar
Dynamat is extremely overpriced! And what you laid down only cuts out low vibrations for the most part. Different materials will cut out different frequences, from the low to the high. I use eDead at edesignaudio. It's a great value and you can buy by the sq. ft so you'll only buy as much as you need. Since you've done the mat, all you need is v3 (liquid that dries hard great for hard to reach places and contours) and v4 (cuts out high frequencies like wind noise)
Old Mar 24, 2009 | 03:17 PM
theloxmyth's Avatar
Fit Gadget Freak
Nice job, brother!
