Wiring Diagram???
Old Mar 29, 2009 | 12:20 AM
clo_GE8's Avatar
Wiring Diagram???
Hello All,
I need your help. I believe there is a couple of members on the forum that already have the service manuel for the 09 Fit. Can you provide a wiring diagram for the instrument cluster? I'm intrested in the wire that sends the RPM signal to the tachometer. Want to install one of these.
Ecliptech - Shift I™
Thanks.
Old Mar 31, 2009 | 09:41 PM
clo_GE8's Avatar
No responce from anybody. No help??
I guess I can't do an DIY for those that would be remotely interested.
Old Mar 31, 2009 | 09:43 PM
JDM_DOHC_SiR's Avatar
Give me a hour or two and I'll post up the color you need ...
Old Mar 31, 2009 | 10:52 PM
clo_GE8's Avatar
Cool! Thanks JDM_DOHC_SIR!
Old Apr 19, 2010 | 09:00 AM
noel15's Avatar
Need Help
Can I have it too, please?
I also want to install aftermarket tachometer but I don't know where I can find RPM/Tach signal cable?
Old Apr 19, 2010 | 07:17 PM
rcntype's Avatar
I think I have one, what info do you need?
Old Apr 20, 2010 | 12:20 AM
clo_GE8's Avatar
Give me some time and i'll dig out the service manuel and scan the sheets you need.
Old Apr 20, 2010 | 12:55 AM
noel15's Avatar
Thanks guys,
I try to install aftermarket autometer on my GE8,
All 3 of 4 cables came from the tach was installed, only one cable left (green cable) which is as per autometer wiring diagram should be connecting to coil or ignition box?
Many suggestion said that I have to connect it to RPM/Tach signal, but they dont give me the detail of location of the cable.
Tht's why I asked your help if might be you have wiring diagram to locate position of RPM/Tach signal cable on GE8?
Do you think is the solution to my problem?
Old Apr 20, 2010 | 09:06 AM
noel15's Avatar
Did you find it?
Old Apr 27, 2010 | 10:52 PM
clo_GE8's Avatar
noel15,
still need the wire for your aftermarket tach?
polokid69
Jun 10, 2011 03:41 PM
noel15
Apr 19, 2010 11:51 PM
noel15
Apr 19, 2010 11:47 PM
09blackfit
Nov 20, 2009 05:49 PM
timster
Jun 26, 2006 12:19 PM
