Wider tires on Base Fit
Old Apr 17, 2009 | 09:28 PM
Lek's Avatar
Lek
My friend just bought a Taffa White base fit with a mugen body kit and loves the wheels, but hates the 175 / 65 R15 narrow tires as they don't hold the road so good.
What are the widest all purpose tires that can safely be put on these stock rims.
He's also talking about painting the wheels white. Has anyone seen a pic of them painted white? Maybe can post a link.
Tanabe NF lowering springs are also on his mind, but there's only 160mm of ground clearance on the front skirt before the drop. Hmmmm
Old Apr 17, 2009 | 09:49 PM
it's pronounced iVTEC's Avatar
i'm just guessing but you could probably fit some 200's on there, but i'm not 100% sure
Old Apr 17, 2009 | 10:05 PM
wpyeo's Avatar
if i'm not wrong, u may upsize your tires to 195 for the 15inch rims..
Old Apr 17, 2009 | 10:20 PM
Lek's Avatar
Lek
Just got this e-mail from Tire Rack, the question is how wide are the stock rims on the base fit. My friends car isn't here right now.
(As long as the wheel is at least 5.5" wide, you can go up to a 205/55R15. That would be noticeably wider, a little over an inch of extra width.)
Old Apr 17, 2009 | 10:34 PM
Virtual's Avatar
Stock rim on base Fit is 5.5 inches wide.
195/60R15 should be a good choice. The diameter difference is only 1.08%
from the original 175/65R15 size.
Check this site to compare diameter differences between sizes: Tire Size Calculator - tire & wheel plus sizing
ghettoboy247's Avatar
215 nah jah p'lek?
Old Apr 17, 2009 | 10:39 PM
Lek's Avatar
Lek
Tire Rack (As long as the wheel is at least 5.5" wide, you can go up to a 205/55R15. That would be noticeably wider, a little over an inch of extra width.)
215 nah jah p'lek?
That's what I thought, but they are the pros.
Actually, Honda said nothing larger than 175 / 65 R15.
One extrem to the other. Who's right?
Another option would be to change to a 16" wheel. How much extra ground clearance would that give over 15"?
Old Apr 18, 2009 | 12:41 AM
well it wouldnt give it any if you lower the profile of the tire. you want to keep the tire/rim as close as possible to stock, so if you get a bigger rim then you want a lower profile and vice versa
Old Apr 18, 2009 | 10:34 AM
mahout's Avatar
Nice looking Fit.
I'd put 205/50x15's or 205/55x15's on the car if the wheels are at least 5.5:" rim width )inside the flanges) and the wheel offset is 53 mm stock or not less than 45 mm if aftermarket. And especially if he lowers realistically 1-1.5".
The 55's are closer to stock diameter but are heavier; the 50's are smaller diameter which helps for a heavier tire to get better mpg and acceleration,, but will mean a 3 mph error i(indicated 60 at true 57) at 60 mph and 30 miles extra per thousand odo miles.
That help?
hogwylde
Feb 6, 2014 09:26 AM
Gregg
May 30, 2013 05:11 PM
kancerr
Aug 13, 2012 09:17 AM
chrisvaccaro
SoCal Classifieds
Jul 6, 2010 02:31 PM
jits14
Car Shows, Events, and Racing
Jun 4, 2008 06:52 PM
