17x7 or 17x7.5?
Old Apr 23, 2009 | 12:37 AM
it's pronounced iVTEC's Avatar
17x7 or 17x7.5?
which rim would be a better choice? or does it really matter. i'm staying to around a +45 offset
Old Apr 23, 2009 | 12:50 AM
blackvitzrs's Avatar
go with the narrower rim for lighter weight usually. But if you want the SLIGHTLY stretched look, then go with the wider width. IMO, i'll just stick with 17 by 7.
Old Apr 23, 2009 | 12:56 AM
thats what i was thinking too.
another quick question, i've heard alot of talk on here that a +40 offset would not work if u want to lower it, is that true? (i'll probably run 205's with a 45 profile) the rims i'm looking at are 17x7 +42
my second option is a 17x7 +40
i'm also looking at a set of 17x7.5 +40's
would any of these fit properly if i throw a set of lowering springs on?
Old Apr 23, 2009 | 01:53 AM
from what i heard, the 7 inch width with a +42 offset will work on a 205 tire. If you go +40 it might be cutting it awfully close. I want to know if the 40 offset will work because i have a set (but i haven't bought the GE yet). It works nicely on my echo. lol
so conclusion, 40 offset on 7.5 will definitely not work once lowered.
Your safest bet is to go with the 17 by 7 +42.
Old Apr 23, 2009 | 07:45 AM
AshPanda's Avatar
Sounds like your thinking BuddyClubs?
but yeah my wheels are 17x7 +42 and i am lowerd on RS*R ti2000, thats 2 inchs of lowering, and i dont have any rubbing or issues for my wheels or car.
Old Apr 23, 2009 | 11:21 AM
actually i was thinking motegi's! buddy club is really expensive my limit i set for myself is $200 CAD a rim
thanks for all the help guys, really appreciate it
Old Apr 23, 2009 | 11:51 AM
AshPanda's Avatar
Question
Well today is your lucky day!
Heeltoe auto has freeshiping on top of the cheapest buddyclub prices.
Buddy Club P1 Racing SF 17X7.0 ET42 4X100 White, BC01-SF177042410-W - 17" - P1 Racing SF - By Brand: Buddy Club - Wheels & Assoc - HeelToe Automotive
BuddyClub > Motegi
Old Apr 23, 2009 | 12:23 PM
for your bicycle i'd stick to like 2" max width.
Old Apr 23, 2009 | 02:32 PM
phoryu2nv's Avatar
i got the same question, i'm lookin to get 17x7 rpf1 in the "special coating" color the offset is +43, going to lower the car with either eibach prokit or df210s, i should be ok right?
Old Apr 23, 2009 | 04:51 PM
AshPanda's Avatar
you'll be fine.
Old Apr 23, 2009 | 05:01 PM
BuddyClub > Motegi
Free shipping only to the US, lol. that is a good deal and buddy club is better than motegi but the price is still steep, the motegi's i found are $135. also i want to try something different, like some 10 spokes.
oh and as for my bike rims, there's 2's on it right now, i have 3's on my full susp lol they're better for when i go back to the mountains
Old Apr 23, 2009 | 09:01 PM
what are the exact motegi rims you want to buy. make sure to check out the weight. Some of the motegi rims weigh a ton.
Old Apr 23, 2009 | 11:12 PM
Well, i went down to every tire shop in town and they all carry Motegi, but none of them can get that rim, let alone in that size. it's a special order apparently. but most of them said Enkei would be the way to go and they have them mostly in stock
i WAS looking at Motegi SP10
https://www.streetortrack.com/files/...otegi/2748.jpg
Old Apr 23, 2009 | 11:30 PM
deranged's Avatar
hey so reading this thread and i am looking at getting some 17' tenzo wheels with a 205/40/17 tire says they will fit, but will they fit with my drop. 1.2 in the front and 1.4 in the back
Old Apr 23, 2009 | 11:39 PM
Depends what offset the wheels are
Old Apr 23, 2009 | 11:44 PM
deranged's Avatar
what is that offset?
Old Apr 23, 2009 | 11:50 PM
wheel offset is distance between the wheel centerline and the hub flange (where the wheel is mounted to the car)
the higher the number the closer to the engine the wheel would be, a +30 offset would be farther away from the engine and the wheels would usually stick out from the fenders depending on the car, and a +50 offset is the opposite, it makes the tire sit closer to the engine
offset also has a major effect on drivability too much offset and your car will be much harder to drive, and vice versa
pretty good explanation
Old Apr 23, 2009 | 11:58 PM
deranged's Avatar
cool, understand thanks
Old Apr 24, 2009 | 01:59 AM
I did a quick search, and the SP10 comes in at 16.8 pounds for 17 by 7. That is pretty light considering its casted. Good choice there. Just don't go with anything more than 18 or 19 pounds then you should be fine.
Stay_Fitted
Jul 22, 2013 09:45 AM
sabawballs
Aug 17, 2012 04:11 AM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
taFITta_sport
Aug 8, 2010 01:20 AM
dcmcelreath
Oct 21, 2007 02:58 PM
