GE8 Seat rails!!??
Old Jan 7, 2011 | 03:12 PM
ThEvil0nE's Avatar
JURAN, BER, Silk Road makes GE/GD rails
Old Jan 7, 2011 | 05:02 PM
cd4ag's Avatar
Originally Posted by Tedkou
I just left mine unplugged. Gonna "black tape" the light as soon as it warms up.
Do u know if that means the rest of the system is still active? or if the light comes on does that disable the system? Can u stick a resistor in there or anything?
Old Jan 8, 2011 | 01:49 AM
Tedkou's Avatar
Yes, the rest of the system is still active. Tho I believe (if all my research was correct) any of the duel stage air bags will only fire at the max speed.
Old Jan 12, 2011 | 01:29 PM
AJR Jay's Avatar
If you're still looking for rails, we can get this for you. We can bring in the Bride rails, the only downside is since we're currently sold out, we need to bring more in which will need to be ordered in.
If you have any inquiries, let me know and I can be glad to help.
Regards,
Jason @ AJR
Old Sep 2, 2011 | 06:54 PM
RetroAttack's Avatar
Hey Guys, Questions on some good places to get rails from?
I just ordered some Bride Digo seats and i need to find some rails to mount them to.
I was looking at the MO or YO type rails are the ones bride says fit the seats.
Is there any others that work with these seats?
Old Sep 3, 2011 | 09:38 AM
Chad T's Avatar
Get the brackets from Wedge Engineering. Driver's side 2148T Pass side 2149T. On the sliders there are only a couple different types from Recaro. Make sure you get the ones that say "with tabs".
You can see bracket and sliders here. I actually cut the tabs shorter on the front of the sliders so I could use the bottom mounting holes.
The tabs on the sliders bolt to the ends of the tubes on the top of the bracket.
As far as the airbag light goes..On the driver's side all you have to do is remove the seat posistion sensor from the stock seat and leave it plugged in. Just make sure it won't contact any metal.
Then just jump the airbag connector with a 2 ohm resistor. No airbag light for me and I've had my recaro in for about 3 months now. You can read more about my install here.
https://www.fitfreak.net/forums/2nd-...ll-begins.html
The passenger seat is much more complicated as far as airbag sensors. I didn't put a seat on the pass side.
DO whatever you need to do to get Recaros in your Fit!!! Makes a huge difference.
Old Sep 5, 2011 | 10:07 AM
wetphoto's Avatar
Everything is always so difficult with the Fit.
Old Sep 5, 2011 | 01:46 PM
FitSSM2k10's Avatar
Not too difficult. A&J sells the seat rails...
Bluflu
Dec 28, 2023 04:33 PM
Dafeex
May 17, 2018 08:19 PM
Wafulz
Jan 14, 2013 09:20 PM
andyd
Feb 11, 2008 12:59 AM
tylermiyamoto
Feb 9, 2008 04:15 PM
