Removal of cargo area trim...
Old Jun 15, 2009 | 03:39 PM
Malice101's Avatar
Question Removal of cargo area trim...
Help!! I had to pull my shocks Saturday night to trim the bump stops and dropped the large washer down between the shock tower and plastic liner...I've tried prying up the side wall a little and fishing with telescoping magnet and having no luck. I've resolved to having to remove the liner or at least a portion in order to get at it. I've got the rear section started but fear breaking something. You can see from the pic I've attached where I'm at in the process but at this point I'm not sure where to go. It feels very very secure in the middle. Are there posts that simply pop down through the middle section going from left to right? The edges pop away easily enough...
Old Jun 15, 2009 | 04:00 PM
jimbob's Avatar
I had that very piece off last night. I wedged my fingers down where the piece meets the carpet in the cargo area and slowly lifted straight up. It popped right off. 4 push clips is all that holds it on...
Old Jun 15, 2009 | 04:08 PM
TekXoID's Avatar
Couldn't tell you myself, but the plastic in the same spot on my GD3 just pops right out, it's only held in by a few clips. Hope this helps:
Old Jun 15, 2009 | 04:33 PM
Malice101's Avatar
Thanks guys...took a pic for future reference. Of course I dropped the washer I was using as a temp after I fished the factory washer out
Old Jun 15, 2009 | 05:58 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
in the rear of the fit everything just pops off. just have to pull a little hard.
Fitsme5312
May 3, 2022 04:44 PM
ctyt
Dec 22, 2017 04:49 PM
GrayGhost
Oct 28, 2015 10:53 AM
ciref8
Apr 9, 2013 05:45 PM
Claudel
Dec 29, 2012 06:38 PM
