lowing question....???!!!!
Old Jul 30, 2009 | 09:32 AM
EggHead's Avatar
Question lowing question....???!!!!
Ok i just ordered the Eibach Sportline Springs wich will give the fit a 2in drop... What im worried about is if there will be any rubing or bottoming out?? im kinda a nub at this...
I did a search on here but was not much help...
does anyone have these? and do you experance any rubing? this is my daily ride will i be able to clear most of the streets in Dayton Ohio? will i be able to have more then 2 ppl in the car with out rubbing my finders off?
Any help/pictures will be obliged cause im thinking of not doing it.
im kinda
Old Jul 30, 2009 | 10:45 AM
Wopasaurus's Avatar
I'm sure you won't have many rub issues. You'd probably have issues if you got bigger tires, or wider ones.
As far as bottoming out... drive carefully over bumps, or get the Eibach Prokit springs which only drop it a little over an inch.
Old Jul 30, 2009 | 11:11 AM
fit-jagger's Avatar
i have eibachs sportlines and i tend to bottom out just the plastic piece under the front bumper
where theres dips but im using 17x7.5 et40 and 205/40/17 tires
and on hard turns theres fender lining rubbing i lost 4 fender screws already but i drive pretty hard sometimes
i think you will be fine if you use a higher offset wheel size and skinnier rim
and with the sportlines the car is more raked
heres some pics hope this helps
Old Jul 30, 2009 | 11:36 AM
EggHead's Avatar
i think you will be fine if you use a lower offset wheel size and skinnier rim
For right now i have the factory 16in rims and tires....
Old Jul 30, 2009 | 12:41 PM
EggHead's Avatar
ordered the pro kit instead i like to set low but it wouldn't be practical plus i plan on putting 18in rims on in the spring lol so alittle extra room does help
Old Jul 30, 2009 | 01:11 PM
fit-jagger's Avatar
if it helps ill be putting the stock 16's when it stops raining that will prolly be on saturday
Old Jul 30, 2009 | 01:17 PM
mahout's Avatar
im kinda
There are thousands of posts regaeding rubbing with lowered suspensions.
our rule is
wheel offset between 44 and 48 mm, tire size not exceeding 23.3" diameter and sexction width 205 max.
Old Jul 30, 2009 | 01:23 PM
sportlines drop the car quite a bit more than prokit.... and prokit starts out with a mild drop but they tend to settle over time for a typical 1.5" to 1.8" drop.
Old Jul 30, 2009 | 01:27 PM
fit-jagger's Avatar
i meant higher offset
sorry
Old Jul 31, 2009 | 10:00 PM
mahout's Avatar
sorry
You were right the first time: lower numerical offset with wider wheels. Just not less than 44 mm on 7" width.
Old Aug 1, 2009 | 12:13 AM
fit-jagger's Avatar
sorry just got confusing thanks
Old Aug 1, 2009 | 01:17 AM
stalonehong's Avatar
really?! so if the sportlines are a 2" drop, how low will it be after it settles?
Old Aug 1, 2009 | 01:30 AM
fit-jagger's Avatar
after 3 weeks
umm with my 205/40/17 the front gap a 3/8 of an inch and the rear is 1/2 an inch gap
bjvalencia
28
Apr 27, 2012 12:55 AM
NewFitGuy09
May 16, 2011 01:02 AM
uhhitsfuzzy
Apr 30, 2010 11:48 PM
xonexlifex
Dec 20, 2009 04:30 PM
logistixz
Apr 18, 2007 08:48 PM
