Electrical Problems...
Old Aug 15, 2009 | 11:34 PM
8o8diff's Avatar
Has anyone ever encountered a situation when your lights dim when you use and power accessory... eg. power windows, radio, etc.
Im just askin around, I've solved the problem but wanted to hear any feedback from fellow ge owners...
thanks
Old Aug 15, 2009 | 11:50 PM
CBX's Avatar
CBX
This raises the obvious question; What did you do to solve the problem?
On a side note, I love it when switching on the power amp for my stereo dims the lights in the house!
Old Aug 16, 2009 | 11:35 AM
FiT4Kim's Avatar
a solution would be nice
Old Aug 16, 2009 | 11:46 AM
Chad T's Avatar
Looks like he installed a grounding kit. Not a bad idea with just the one wimpy ground going from the batt to the rad support on these cars.
Originally Posted by 8o8diff
My list of mods:
-HyperGround system to help with shetty electronic system... it really works!!!
__________________
Old Aug 16, 2009 | 05:43 PM
8o8diff's Avatar
Thumbs up my solution
I've installed a complete grounding kit..
HyperGrounds battery mr system and the original cables the company made when they first started.
I still use the factory ground straps along side the system..
*Trick for no corrosion use battery grease when your done with the install so that you dont have to worry about the ground point building corrosion.
After installing just the battery ground my throttle response is greatly improved and my lights never dimmed...
Any1 with electrical issues? waiting for those
epijimenez
Jun 28, 2014 12:00 AM
DarkPuppy35
Oct 22, 2012 01:43 PM
kdean101
Feb 26, 2009 01:36 PM
sillypuddy
Nov 23, 2006 03:34 PM
Phil
May 4, 2005 11:16 AM
