Improving the handling of my '09 Sport M/T Fit
Old Sep 15, 2009 | 01:05 PM
yep. just lowering the car on springs wont help. it will actually degrade the overall performance. i will leave it at that.
Old Sep 15, 2009 | 03:24 PM
eldaino's Avatar
cant emphasize this enough. curiously though it deters no one.
the average fit driver who mods is unfortunately more concerned with looks than performance.
Old Sep 15, 2009 | 03:42 PM
Committobefit08's Avatar
does anyone have a pic of their GE with 205/50-16 on their stock rims? Just curious to see them.
Old Sep 15, 2009 | 05:30 PM
Watsoff's Avatar
+1 on this request. Only, can we get a back view (tread view?).
Old Sep 15, 2009 | 07:40 PM
Btrthnezr3's Avatar
Yea, that would be nice...subscribed for picture.
Old Sep 15, 2009 | 07:52 PM
awptickes's Avatar
Will that even fit? It'd be interesting to see an 8" wide tire on a 6" wheel.
I got turned down by a tire shop to put a 195/50 on a 6" wide wheel. They were incompetent though.
Old Sep 15, 2009 | 08:01 PM
Lek's Avatar
Lek
There's also a trade off issue with 16" wheels and wider 205/50/16 tires.
After I had them fitted, I noticed more road grip straight away, but the car rolled/swayed a lot more from the wider tires. After 2 weeks of driving, I put my original wheels back on the car to test and for sure much less roll/sway.
But I must say the car looks much better with wider tires and my coilovers balance the trade off.
Old Sep 15, 2009 | 08:10 PM
Lek's Avatar
Lek
Oh, and here's my other baby with 205/50-16. I know a Yaris on this forum.
Old Sep 15, 2009 | 10:52 PM
Watsoff's Avatar
Looks like a decent fit...not like some of the insane wheel to tire size matches i've seen in the biker circles...sway has been noted, BUT, which 205/50/16 set did you put on?
Old Sep 15, 2009 | 11:53 PM
mike2100's Avatar
I think he meant he wants to see what a 205/50-16 looks like on a stock Fit wheel, not what 205/50-16s look like on the car. At least, that's how I understood it... and I'm curious as well.
Old Sep 16, 2009 | 12:02 AM
Lek's Avatar
Lek
Not recommended to put this tire on a stock wheel.
Old Sep 16, 2009 | 07:34 AM
  #32
Chad T's Avatar
According to Tire Rack the recommended rim width for 205/50/16 is 6.5 with 5.5-7.5 being the acceptible range. How wide are the stock sport rims? If they're 6 inches the 205 will fit fine.
Old Sep 16, 2009 | 07:38 AM
  #33
Watsoff's Avatar
meh, yeah it was late when i replied. 205/50/16 on a stock rim, or aftermarket rim of same size. lotta folks are putting the 205 on and saying the fit is good, and they've noticed improved handling...I'm fine with going up a size or two on the width. Even though his pics included aftermarket wheels, i guess i thought they were the same size.
anyway, yeah, looking to see tire fit at rim for 205 on stock or same size wheel....not how they look on the car.
Old Sep 16, 2009 | 08:49 AM
  #34
Lek's Avatar
Lek
Ask Honda, they are just a phone call away. Safety first with this one.
Old Sep 16, 2009 | 11:18 AM
  #35
Watsoff's Avatar
ok, great, limme give 'em a call
Old Sep 16, 2009 | 11:44 AM
  #36
Exactly
I did.
Any pics with 205/50-16 on STOCK rims please.
Old Sep 16, 2009 | 12:18 PM
  #37
guys are going in the wrong direction if you want to improve handling.
get the stock size tires but a higher quality one.
your wheels are only 6" in width right? 205 on 6" is going to be
pretty sloppy for any performance driving. if they were 16x7.5's
(minimum 16x7) i would consider 205/50's... but for your stock
wheels, run stock size or just lower the profile.
Old Sep 16, 2009 | 01:04 PM
  #38
Everyone I've seen running 205's say the handling is better. I'm just going off of what others are saying.
SCBarren just put 205/55-16's on his GE. See here...
https://www.fitfreak.net/forums/2nd-...tml#post747480
Old Sep 16, 2009 | 01:52 PM
  #39
better probably because it's a better tire than the stock tires. but if you want to maximize the car's responsiveness see if you can find the grippiest tire in the stock size. it will net you the most performance with the smallest side effect (tramlining, etc)
wider does not necessarily mean better traction unless you're using the same tire. it's the structure and compound that really counts. the wheel also reinforces the structure if you use the right width wheel too.
and the werd is too much grip can also slow down your car.
Old Sep 16, 2009 | 08:51 PM
  #40
blyndgesser's Avatar
Unfortunately tirerack.com only lists the stock replacement tires (Bridgestone Turanza EL470 and Dunlop SP Sport 7000 A/S) and some Bridgestone Blizzak snow tires in the stock 185/55-16 size.
