iVTEC and RPM
Old Sep 23, 2009 | 09:45 AM
ZXRider's Avatar
iVTEC and RPM
I do not know how the iVTEC works on the Fit, but on my 98 Prelude VTEC would be activated at 5500 RPM, Wondering if it works the same way in the Fit and at what RPM it engages?
Thanks,
Old Sep 23, 2009 | 10:18 AM
Committobefit08's Avatar
this sums up ivtec pretty good.
VTEC - Wikipedia, the free encyclopedia
here is some more info also..
On the road, the Fit's 1.5L SOHC 16-valve 4-cylinder (117hp@6600 rpm, 106lb-ft@4800 rpm, codename L15A7) has been fortified with "real" VTEC, meaning it actually has dual discrete lift profiles that the intake valves follow, and the difference over last year's "mild" VTEC motor (which switched between 3- and 4-valve operation) is immediately noticeable. On paper the differences don't sound like a lot (+8 hp, +1 lb-ft) but the new version of the engine makes noticeably more torque everywhere below 4000 rpms and above about 5500 rpms, and the difference can easily be felt. To multiply this additional thrust, and to further offset the '09 Fit's weight gain, the effective gear ratios of the 5-speed manual transmission are shorter by anywhere from 3 to nearly 8 percent. The Fit's clutch takeup feels better than before, and the shifter action has been improved thanks to a shorter stroke and double-cone carbon synchros. Acceleration feels downright perky in the lower gears, and the engine pulls very nicely to its 6800 rpm redline, including a nice little VTEC "kick" on the way up. At idle, the engine is so quiet and smooth, on a few occasions I was startled to discover that it was actually still running. The one downside is that compared to most Honda 4-bangers, this L15A7 gets a little bit gritty in the mid- and upper reaches of the rev band.
Temple of VTEC Rumors and News - TOV First Drive: 2009 Fit is Win!
Old Sep 23, 2009 | 11:03 AM
Red 05's Avatar
+rep for an epic post!
Old Sep 23, 2009 | 11:25 AM
hanzo's Avatar
Around 4500 rpm I hear the engine changes over but didn't really feel much difference in power.
Old Sep 23, 2009 | 05:26 PM
Lyon[Nightroad]'s Avatar
Honda Worldwide | New 1.8l i-VTEC Engine
watch this video and get you eduhondacation. Not all features are included in the 1.5l - most are.
Old Sep 23, 2009 | 11:23 PM
mike2100's Avatar
I wonder what he means by "gritty"
Old Sep 24, 2009 | 12:52 AM
M4psycho's Avatar
This dyno should give you a good idea of your power from your Fit. Dyno comes from AJ-racing, who compared the dynos before and after installation of their exhaust system.
Old Sep 24, 2009 | 12:56 AM
j1nNju1c3's Avatar
Good question! My friend told me that you wouldn't really hear the vtec pop because its only a single cam. But vtec is vtec right?
Just wondering, do AT get vtec too? Like the mini pop? (noob question, i know)
Old Sep 24, 2009 | 01:14 AM
Ivtec has eliminated the 'pop'. The pop is a flaw not a feature. The new ivtec system smoothes out the power curve and allows for increases in power throughout the powerband and yes ivtec is in the AT.
Old Sep 24, 2009 | 02:38 AM
rosswond's Avatar
I've actually found the cam profile transition fairly seamless at around 4000-4500 RPM, apart from the fact that the reves just keep increasing and you have to be quick with the gear change to keep it off the limiter
Old Sep 24, 2009 | 07:48 AM
Good question....maybe loud?
Old Sep 24, 2009 | 08:16 AM
Wopasaurus's Avatar
Yeah... but unless you're using paddle shifters, chances are your transmission will shift itself before you really get there.
Old Sep 24, 2009 | 11:33 AM
Red 05's Avatar
That's at the crank right? Or does that much HP get to the wheels.?
Old Sep 24, 2009 | 01:22 PM
That 102 hp at 6800 rpm should be the wheel hp (stock). Remember this is only for the MT. AT lose more power due to the transmission.
If I remember right a GD3 member said his wheel hp was 98 hp for a MT.
I'm not positive but that 102hp sounds like it should be wheel hp.
Old Sep 24, 2009 | 02:57 PM
12vltfrk's Avatar
im guessing its not as smooth reving up higher in the powerband( a little choppy), thats what i have noted any way
Old Sep 24, 2009 | 03:42 PM
j1nNju1c3's Avatar
Ahh thank you for clearing that up for me
haudoodles
Dec 12, 2014 10:23 AM
Owl
Nov 27, 2012 06:57 AM
mugenpower88
Nov 11, 2008 06:21 AM
Tif
Aug 15, 2008 12:35 PM
ghostfit
Jul 18, 2007 07:56 PM
