Is this not weird? AT has better MPG than MT?!?!
Am i on crazy pills or something? i never knew that automatics saved more gas.. i thought it was vise versa.
2010 Honda Fit - Specifications - Official Honda Web site
5-Speed Manual (City/Highway/Combined) 27/33/29 27/33/29 (Models without Navi)
5-Speed Automatic (City/Highway/Combined) 28/35/31 27/33/30
whats up with that? if i knew that i would have gotten an automatic!
The rating spread is even bigger on there. 20/25 with the auto, 18/23 with the manual.
FOr a real surprise, look at a Nissan Sentra, with the 2.0L. 26/34 with the CVT (about the same as the Fit Sports 27/33) vs 24/31 with a manual.
ahhhh gear ratio that explains it. man that sorta sucks.. i wonder why they did that. cuz most of my driving is highway driving.
yeah i noticed my Fit's RPM was kinda high on the highway.. but i just figured "ehh its a honda... 3k is normal"
Yeah 3k rpms is pretty normal for a Honda. I've consistently gotten more MPG than all of the EPA estimates on all my Hondas (5, 4 M/Ts). The numbers for the Fit are low to begin with anyway and most are in agreement on this site on that. I'm happy with the MPG I get, but I'm not surprised, Honda is awesome.
Aye the automatic has taller gears cruising highway rpms are only 2.5k. The torque converter allows this because it can vary infinitly from 2:1 to 1:1 when the stator is locked. so although the gears appear taller at a 1:1 ratio they are fairly similar when the torque converter is considered. Regardless power is still lost.
~SB
If I cared a bit about 0-60 runs, I sure wouldn't be driving a little Fit. That's like noting that a Jeep Wrangler doesn't corner all that well, or that a Corvette doesn't have much in the way of cargo-hauling space! Still quite an entertaining little car!
in a way.. it doesn't really matter cuz i PREFER driving manual, but i think its kinda jacked up to how manuals suffer more on the highway. highway is about all the driving i do on this car. i guess i should have researched the car more before i bought it.. i basicaly bought this thing for looks and... hoping to save gas.
AT gearing is much better than manual on the interstate. At 70 mph the manual rpm is 3500 rpm while AT is 2525. Theoteically thats 60% higher mpg for the AT compared to manual. The manual is much easier to hypermile than the AT thoough.
Around town the manual is more efficient but at interstate speeds the AT overcomes its mechanical deficiency with much better gearing.
Unless you drive mostly interstate you won't see that advantage.
Next time you buy you should check the mpg ratings first if its that important.
... cruising at 15mph.
EPA test methods are out of whack and worthless when comparing Fit auto/manual.
Go down to the ECO-Fit forum and look at the Mileage reports.
Average out the first ten Auto trans reports and I get 30.1 mpg. The first ten Manual trans reports gets 35.8 mpg.
Under real driving conditions the manual will almost always get better mileage than an auto even with the gearing difference.
If acceleration was important, you could also do alot better for the price of an S2000 as well. STI or EVO comes to mind.
~SB
ruknight4ever
Oct 24, 2008 03:00 PM
